Should this Fan Thermostat work well?
Old Oct 24, 2010 | 07:01 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
Would THIS fan Thermostat work with our temps being that it opens at 185 and shuts off at 170?
Old Oct 24, 2010 | 10:01 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Should this fan switch work well?
I thought for a minute that there was no switch, but that small black box that's in line appears to be it.
I'm sorry I'm not sure if it will work for your particular set up . I'm going to be a interested bystander.
Old Oct 25, 2010 | 10:58 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: Should this Fan Thermostat work well?
Are you running a stock ecm? It would work but the thing is, the cars came from the factory designed to run hot. Basically just for all the emissions crap.
If the car is stock, and you want to make it run cooler, then I would use a hypertech fan switch and also get the ecm chip they sell. They claim it improves horsepower but i doubt it. It will however let you run cooler, with that you could also run a 160* thermostat.
Old Oct 25, 2010 | 04:59 PM
Engine: TBI,5.0
Is this the switch you are referring to?
http://www.summitracing.com/parts/HY...RO&prefilter=1
Old Oct 25, 2010 | 05:09 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
Sorry forgot to mention Im running a carbed sbc,so no ecm. I would like to try to avoid any switches/thermostat that would screw into the head since one head has a plug that is stripped and the other head a sensor type deal in there that is stripped.
For ease of installation,that why I was looking for the probe type.
Old Oct 25, 2010 | 05:18 PM
Twin_Turbo's Avatar
This is what I'm using on all my cars, works well (relay switched fans)
I do not get why people would want to use a stick in core probe type setup w/a bunch of wires if you can use a factory hole in the head and have a factory like solution that is bulletproof and not jerry rigged.
Old Oct 25, 2010 | 06:46 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
What temp would be a good turn on point for a carbed sbc?
How much coolant would I lose if I removed the sensor on the head?
Are the probe style ones really that bad?
Old Oct 26, 2010 | 05:55 AM
Twin_Turbo's Avatar
180-190 is a good temp imo
It's not that the probe is bad, it works and it's simple. You simply stick the probe in the core net to the hot water inlet (upper hose). however you have a hole for a simple switch in the head, why go w/ an aftermarket/non oem solution when you can do it the oem way and it'll look much cleaner w/ proven quality parts.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
TA8487
Aug 16, 2015 12:21 PM
perZ
Aug 15, 2015 01:17 PM
Leggman1
Aug 6, 2015 04:15 AM
