Wrong Fan?
Old Jan 17, 2011 | 09:13 PM
mxxdude's Avatar
Car: 1989 Camaro RS
Engine: TBI 305 STOCK
Transmission: 700r
Axle/Gears: 2.73?
Wrong Fan?
So i recently purchased a 1989 Camaro RS 305 TBI.
Long story short the fan is not kicking on at all. and at idle it overheats but driving it doesnt
So drove the car home and we replaced the fuse then i checked the fan and it was pretty hard for me to turn almost seemed seized. so then i replaced the relay and the switch.
still nothing so we pulled the fan. pulled the fan and hooked it up to the battery and it worked.
SO we put the fan back it and chalked it up to wiring. BUT OH NO GM cant be that simple. when we put it back we relized that the reason the fan wasnt spinning was because it was pushed against the radiator (thats why it was hard to turn)
So can someone take a picture of there electric fan assembly?and post it?
this fan was smashed against radiator and the motor was facing the motor?
thanks just looking for some assistance
Old Jan 18, 2011 | 02:46 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Wrong Fan?
I have a single fan assembly in my garage and I'll try to get a pic tomorrow (or I should say later today).
But I can try to simply describe how it should fit,
The motor does face the engine. The blade should be what is near the radiator. The top of the fan bracket bolts to the plastic part that holds the top of the radiator in place. The bottom of the fan bracket bolts to the radiator support. Make sure that support is not bent. There should be maybe about a 1/2-3/4 inch space between the radiator support lip and radiator at the bottom. Perhaps someone put a jack there and bent it or an accident left it bent.
You can also make sure your radiator is sitting in the rubber isolators at the bottom.
Oh and another thing to look at is make sure your radiator is flat. If it was in an accident it may have a curve to it now that could be contacting the fan.
Old Jan 18, 2011 | 09:19 AM
mxxdude's Avatar
Car: 1989 Camaro RS
Transmission: 700r
Axle/Gears: 2.73?
Re: Wrong Fan?
Thanks.
And i believe i have the right one it just looks like the radiator is out of place because it leans very hard to the engine causing it to hit the fan
Old Jan 18, 2011 | 11:16 AM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
Re: Wrong Fan?
If the fan was pushed into the radiator you should also replace the radiator.
Old Jan 18, 2011 | 12:05 PM
mxxdude's Avatar
Car: 1989 Camaro RS
Transmission: 700r
Axle/Gears: 2.73?
Re: Wrong Fan?
Well the radiator fins are fine i think its just aligned wrong now
Old Jan 18, 2011 | 03:31 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Wrong Fan?
This fan is from a 91 RS and I was mistaken with my estimate for the distance from the radiator to the edge of the support. It should be about 2". I may have been thinking of the front where the condensor has less space.
Old Jan 18, 2011 | 05:45 PM
mxxdude's Avatar
Car: 1989 Camaro RS
Transmission: 700r
Axle/Gears: 2.73?
Re: Wrong Fan?
thanks i have the same fan however when i bolt it up the blades are pressed against the radiator so the fan cant move.soomething is wrong with the radiator its not in there right
Old Jan 18, 2011 | 07:58 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
Re: Wrong Fan?
maybe the lower rad support is bent , someone may have tried to put jack there once
Old Jan 18, 2011 | 08:49 PM
mxxdude's Avatar
Car: 1989 Camaro RS
Transmission: 700r
Axle/Gears: 2.73?
Re: Wrong Fan?
Yeah i think so because the fan seems right and bolts up however it seems like the radiator is too big standig up. so i looked under it and it looked like it was indented in the middle if its straight but not enough to push the radiator up
Old Jan 18, 2011 | 08:53 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Wrong Fan?
Are you sure its pressing against the radiator, and not the housing its in? On every third gen that I have had to install/replace an electric fan in it seems that the upper and lower mounts are too close together and squishes the fan together making it rub on itself. I don't know why but they all do that and I can't figure out why.
Old Jan 18, 2011 | 09:09 PM
mxxdude's Avatar
Car: 1989 Camaro RS
Transmission: 700r
Axle/Gears: 2.73?
Re: Wrong Fan?
im sure the fan is pressing on the radiator not really the individual fin but the middle part that house it
Old Jan 18, 2011 | 09:38 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Wrong Fan?
Like I already stated, someone may have jacked it up there and bent it. With it being bent up it could very well be what is making the fan hit. There is not much space between the fan and radiator to start with so it would not take much.
Since you have your fan out you may just want to pull the radiator and if the support is bent up knock it down with a big hammer and a block of wood.
Also eyeball along the sides of the support for bends or kinks as it could be bent forward a bit as well.
Old Jan 18, 2011 | 09:46 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Wrong Fan?
I did not think of a side pic before but, the front of the fan where it attaches to the motor is flat and from there to the front of the bracket where the motor bolts to is 2 1/8".
But You most likely should make straightening the radiator support a priority.
Old Jan 19, 2011 | 08:31 AM
mxxdude's Avatar
Car: 1989 Camaro RS
Transmission: 700r
Axle/Gears: 2.73?
Re: Wrong Fan?
Yeah alright thanks for the help. Now i have one more question.
I was looking for a better radiator anyway but one that is smaller and i heard the 90s era corvette rad was smaller and would bolt right in. would this fit the bill?
just want something a little smaller anyway but that keeps the car cooler cause these cars do run pretty hot
Old Jan 19, 2011 | 01:13 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Wrong Fan?
Going to a smaller capacity to keep the car cooler does not really make much sense.
Old Jan 19, 2011 | 03:05 PM
mxxdude's Avatar
Car: 1989 Camaro RS
Transmission: 700r
Axle/Gears: 2.73?
Re: Wrong Fan?
Well it work as good as the stock radiator?
i mean its smaller and was designed for a corvette which has way higher performance then my camaro RS
i added a picture the vette rad is on the left
Old Jan 19, 2011 | 04:42 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Wrong Fan?
I would also imagine that some of the ducting and baffels in the Vette design also help with that car.
You want better cooling, install the heavy duty dual fan set up.
I have the dual fans, 195 t-stat and the low-Low temp fan switch (176 degree I think). It takes being stopped in traffic in the heat of the summer and the AC on to reach 220. And 220 is not over heatting
Fanatic1074
Oct 3, 2022 05:57 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
z28joe2
Sep 28, 2015 05:54 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
