Leaking Radiator
Old Jan 21, 2011 | 11:09 PM
D.J.'s Avatar
Car: 1989 T/A GTA
Engine: 5.7 TPI
Leaking Radiator
The radiator on my GTA has sprung a leak where the end cap meets the core. Is this fixable? If not could some one please point me in the direction of a good company that will know what exact modle radiator I need because I am finding alot of the companys seem to dissagree with each other as to which one I need.
Specs are: 1989 T/A GTS, 5.7 (code 8), Auto trans, AC, no oil cooler.
Also, the leak is a streamer so I doubt basic sealer will work. Thank you for your help
P.S. Sorry just saw I double posted and cant seem to delete this one.
Old Jan 21, 2011 | 11:14 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Leaking Radiator
champion ebay radiators are good
Old Jan 21, 2011 | 11:16 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
crack an egg in there itll work lol, my buddy put a bad crack in his partial pre-runner explorer when he was at the dunes, put two eggs in it ands been running it like that for a month now lol
Old Jan 21, 2011 | 11:46 PM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
im sure any Auto Zone or Napa. Might have a good replacement for ya. Does it have plastic end caps with an aluminum core? Or is it an older radiator when they used to know how to build them? I recently found a local radiator guy and had mine cleaned up and cored. Mine is an old school copper radiator. i beleive its copper anyway. I personally would find a radiator specialist instead of an aotu store. price might be a few bucks higher but not usually. good Luck
Old Jan 22, 2011 | 01:25 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
They are fixable. You have to search around and find a place in your area that sell the tanks and seals. I like the easy sure way route though and just replace it.
And the aluminum one row (one huge row) dissipate heat better than the old brass and copper ones.
Old Jan 22, 2011 | 01:31 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
http://www.summitracing.com/parts/PLI-433918/?rtype=10
That should be it right there. You can use that Vista part number and maybe find one local to you.
Old Jan 22, 2011 | 07:30 PM
D.J.'s Avatar
Car: 1989 T/A GTA
Engine: 5.7 TPI
Ok, thanks for the help everyone. It's been a while since I have been in the hobby and had forgotten about Summit, how silly of me. Perfact, thanks again
Old Jan 23, 2011 | 02:40 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
haha well you could do a fix i did on my mothers car ....have you ever heard of JB weld?
its like a superstrong epoxy they sell at hardware stores there is qwik weld and normal i used the normal all i did was mix it the coat it on nd that was a little over a year ago and it hasnt budged just make sure u let it set
Bubbajones_ya
Jul 6, 2024 08:32 PM
sac92transam
Oct 7, 2015 02:31 PM
Stryker412
Sep 20, 2015 06:59 PM
84redta
Sep 19, 2015 09:58 AM
blackandblue02
Sep 10, 2015 08:19 PM
