Coolant temp sensor and coolant temp switch/fan switch
Old Mar 6, 2011 | 07:53 PM
Wolfman720's Avatar
Car: 1985 Trans am/1999 TT vette
Engine: 305/LS2
Transmission: 700R4/T56
Axle/Gears: stock
The coolant temp sensor is right by the thermostat, right? Where is the coolant temp switch/fan switch?
Old Mar 6, 2011 | 07:59 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Coolant temp sensor and coolant temp switch/fan switch
driver side head, right behind the AC compressor
Old Mar 6, 2011 | 08:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Nope - not there - at least not on V8.
Coolant Temp SENSOR (for the computer) - thermostat location
Coolant Temp SENDER (for the gauge) - driver head between #1 & #3 spark plug
Fan Switch - pass side head between #6 & #8 spark plug
Old Mar 6, 2011 | 08:24 PM
Wolfman720's Avatar
Engine: 305/LS2
Axle/Gears: stock
Cool. Thanks. :-)
Old Mar 6, 2011 | 08:44 PM
Car: 1992 RS
Engine: Carbed 350
Now - if you have dual fans, only the secondary fan is controlled by the fan switch, the primary fan is controlled by the ECM. So, if you are having primary fan issues, might be bad fan relay. If having secondary fan issues, might be bad relay for that fan or the fan switch.
Oh - secondary fan should also come on with A/C - so if you have A/C still in tact and pressurized, start car when cold (so you know the ECM won't turn on the primary fan) , turn on A/C, and see which fan runs with A/C on - then you know which is which.
Old Mar 6, 2011 | 08:47 PM
Wolfman720's Avatar
Engine: 305/LS2
Axle/Gears: stock
Its a big single fan (14 inch).
Old Mar 12, 2011 | 07:56 AM
Cwaterboy1's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI
How the heck do yo get to the Fan switch on the 305, from underneath? I hope not....I am a big guy and to get the car off the ground would be a chore.
Old Mar 12, 2011 | 10:13 AM
torque_is_good's Avatar
you can get to it from underneath and you can also fit a wrench between the primary pipes of your headers. You do have headers don't you?
If not, underneath you go
Old Mar 12, 2011 | 10:58 AM
Cwaterboy1's Avatar
Engine: 5.7 TPI
I do not have headers......so underneath I go. Or just take it the nearest shop and have them lift it up and do it. I hate paying for the labor when I can do it. Just getting underneath will be a chore.
I did check the fan and it does not come on when the temperature rises but does come on when I run the AC. Right now my AC doesn't work so I never run it. Am I replacing the right part?
Old Mar 12, 2011 | 12:49 PM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
I have dual fans and when my car gets hot the fan on the right- drivers side will go on but the one on the left passenger side NEVER comes on??? Is that considered the secondary fan thats controlled by the switch?
Old Mar 12, 2011 | 01:11 PM
Cwaterboy1's Avatar
Engine: 5.7 TPI
Found that the pigtail with the plastic connector to the switch was missing so the wire was just hanging there. Connected a new pigtail from Oreilys $10.00 and all is good with overheating.
Old Mar 13, 2011 | 02:03 PM
JimRockford's Avatar
Does anyone here know what temperature the fan switch should be activating the fan at?
My car runs cool on the freeway but warms up to around 220 and a little higher in stop and go traffic and the fan doesn't seem to come on until over 220.
I have called all the local auto parts stores and they have the fan switch in stock but they can't tell me what temperatures it works on.
When can I find one that will turn the fan on sooner?
Old Mar 13, 2011 | 05:06 PM
Car: 1992 RS
Engine: Carbed 350
220 is normal operating temp for these cars. Alternative switch part numbers can be found by searching "fan switch" and look for a thread that reads alternatives in the title.
Old Mar 13, 2011 | 07:44 PM
Got it "Camaronewbie"!
Neihoff DR137x is the cooler fan switch and turns on at 204 degrees.
The only problem is none of the local auto parts stores can get it!
Also my car has the 305 TBI v8 with single electric fan,where is the fan switch located on the single fan cars?
Old Mar 13, 2011 | 07:46 PM
tubbytownsend13's Avatar
Car: 87 iroc
Engine: mostly stock 5.7
Transmission: jasper stage 2 700r4
Axle/Gears: stock
heres my dillemma, 87 iroc 5.7 tpi wire is there for the secondary fan for the fan switch...problem is i believe someone put a plug in the head where the switch was.....should i just take plug out and put switch there?
Old Mar 13, 2011 | 08:50 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Fan switch is in the head between the #6 and #8 spark plug
Old Mar 13, 2011 | 08:54 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Read this stuff
https://www.thirdgen.org/forums/cool...ernatives.html
Old Jul 13, 2013 | 04:12 PM
Dave Beardsley's Avatar
Does anyone know where the fan switch is on my 92 firebird v6.
Old Nov 15, 2013 | 05:39 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
im intereted in knowing about the v6 too
Old Mar 22, 2015 | 07:18 AM
csobusa's Avatar
Car: 86 camaro
Engine: 2.8 v6
on the v6- passenger side head rear buried by wire harness has a funny snout type connector
Old Mar 30, 2015 | 03:30 PM
1991firechicken's Avatar
Engine: 305 TBI
Looking for advice. I have a 91 Firebird 305 tbi. It has been hard to start for years. The culprit wound up being a bad coolant temp sensor (next to thermostat). The guy at the parts store told me to wrench it all the way into the hole. Several other people have said that it is not supposed to go all the way in. I am hoping that I haven't damaged the intake. Any thoughts/opinions on this?
Old May 6, 2015 | 10:42 PM
mshackelford's Avatar
Car: 1991 RS
Engine: 305 TBI
Transmission: 700R4currentT5WC in garage
OK we now that i know where to find the sensors and which ones do what. Do any of you all know how a person would go about testing them with a voltmeter? I know im not into blowing cash on parts that are not needed. Id rather be buying ones that are needed.
Old May 11, 2015 | 09:53 PM
89 formula TPI's Avatar
Engine: LB9 5.0L TPI
Axle/Gears: 9-bolt Borg Warner, 3.45
Does my AC have to be charged for the secondary fan to build enough pressure to spin? AC works just blows warm
Old Jun 25, 2018 | 05:08 PM
Matteston1993's Avatar
If your temperature sending unit in the driver's side head isn't working will that throw the motor off and cause slight back firing at loss of power
Old Jun 25, 2018 | 05:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Dead thread, on a v8 the drivers side sensor is for the temperature gauge.
Old Jul 12, 2018 | 04:29 AM
rmartindc's Avatar
Car: 1992 Camaro RS
Do you have a part number for this? I think mine might have melted and is therefore shot. Thanks!
Old Jul 12, 2018 | 06:29 AM
That post was from 7 years ago.
http://lmgtfy.com/?q=gm+fan+switch+pigtail Go ahead, you're smart, you can DO THIS.
Old Jun 9, 2019 | 05:36 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
eightsixseven
Dec 16, 2024 01:50 PM
Bstrang6
Sep 8, 2015 04:29 PM
TheExaminer
Aug 26, 2015 04:59 PM
