Cooling fan issue
Old Jun 18, 2011 | 06:37 PM
silverado638's Avatar
Car: 1985 IROC-Z
Transmission: borg warner 5-speed
Axle/Gears: stock
Cooling fan issue
If this problem has already been posted could someone please point me in the direction of it but the electric fan on my 85 iroc will kick on for a second and shut back off. The volts drop down from 14 to 12 while its engaged and then a second later it kicks back off and the volts go back to normal. Is this a wiring problem or is the fan motor taking a crap? Any help would be greatly appreciated.
Old Jun 19, 2011 | 12:17 AM
RyanEricW's Avatar
Re: Cooling fan issue
How are you measuring the voltage?
Old Jun 19, 2011 | 06:37 AM
Car: 1985 IROC-Z
Axle/Gears: stock
just off the volt guage
Old Jun 19, 2011 | 06:49 AM
maccamenzies's Avatar
Car: 1988 Transam
Engine: 5litre
Dont think the car volt gauges are accurate enough.Grab a multimeter and check it with that.Run a amp meter across the circuit and see home many amps its pulling when it kicks in
Old Jun 19, 2011 | 09:25 AM
Car: 1985 IROC-Z
Axle/Gears: stock
ok so new scenario, i just put a flex-a-lite fan controller on and it popped a 20, 25, and 30 amp fuse. Bypassed the fuses all together and the fan started running but the box then started to smoke. Any idea whats goin on at this point? I think my only other option is an entirely new fan but I don't wanna buy it and that not be the problem so i'd just like a lil conformation from somebody before i go that route.
Old Jun 19, 2011 | 06:25 PM
Car: 1988 Transam
Engine: 5litre
It appears that the circuit that runs the fan has a fault to earth.My suggestion would be to run a hot wire through a line that runs from the ignition when on.Run that through to your controller through a fuse and all should be good. I had a similair problem where my fan ceased causing the fuse not to blow and burned out the wiring.I had to run a new hot wire and bought a thermatic controller and all works good.
Old Jun 25, 2011 | 05:18 AM
Car: 1988 Transam
Engine: 5litre
Further to that check out this link to wire up the fan correctly.This is a separate circuit to the vehicle one.
http://www.daviescraig.com.au/Images...(08-08-06).pdf
Old Jun 25, 2011 | 12:52 PM
RyanEricW's Avatar
I wonder if there is still a thirdgen out there besides mine that isn't wired up all ghetto. I would've just fixed it the right away, not necessarily installed a whole new kit to try and bypass a probably (easy) fix.
If I were you, I would run a brand new power/ground wire straight to the battery, andsee if the wiring burns up. If so, your fan has a short in it.
Old Jun 25, 2011 | 02:13 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Thats normal.
It will also do that when you turn the lights on or the blower fan or anything that uses electricity..
Just replace the stock fan motor with a new replacement motor if you feel the stock fan isnt pulling enff air.
Old Jun 25, 2011 | 08:42 PM
Car: 1985 IROC-Z
Axle/Gears: stock
whats ghetto about an adjustable fan controller? you shoulda saw all the wiring before I got it, if anything i'm trying to clean it up
Old Jun 25, 2011 | 09:04 PM
RyanEricW's Avatar
It's ghetto because it doesn't need to be adjustable, and the factory way of cooling works if you just fix it the right way. I bought one of those adjustable fan controllers before too, so I'm not saying I'm innocent, but to be honest they are a workaround for technical incompetence.
Old Jun 25, 2011 | 09:40 PM
Car: 1985 IROC-Z
Axle/Gears: stock
to each its own i guess because you didn't see what i started off with when i bought my car. whoever had it before me did a hack job and instead of spending time researching exactly how it was originally wired from the factory and with advice from fellow 3rd gen owners on this forum this is the direction they told me to go in so if my car is ghetto because i can adjust at what temperture my fan turns on so be it.
Old Jun 25, 2011 | 10:20 PM
RyanEricW's Avatar
I don't mean to be offensive, I just can't stand when people just add to the hackjobish #$^^ I see in these cars. My first thirdgen I had was like this, and fixing it was a damn nightmare in itself....so I can empathize. So when I see people wiring up "switches" to turn their fan on manually and what not, that is just absurd when it's faster, simpler, and cheaper to fix the initial issue.
Not sure if it's like this on your year, but on my 92, all there is a fan switch sensor (grounds relay circuit once it reaches X temperature), a relay, and the fan.
Ground the wire from the sensor onto the starter housing to check the sensor switch.
Check the relay for any faults (apply +/-) to the control circuit to "activate" the eletro-mechanical switch, which you will hear a "click" if its working.
Check fan to make sure it spins with power/ground applied by jumper wires.
Not too hard and very cheap.
Sensor switch? $9
Relay? $10~
Fan? $20 at local junkyard?
Replacing each of this is much faster than wiring in aftermarket or manual override switch.
Old Jun 26, 2011 | 01:06 AM
TTOP350's Avatar
I wouldnt buy electrical stuff from a JY.. buy fan motors and stuff new..
Old Jun 26, 2011 | 01:22 AM
RyanEricW's Avatar
Personally, me neither, but it's still a low cost option if you have a dead one. Many junk yards around here have 30 day warranties as well.
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TheExaminer
Aug 26, 2015 04:59 PM
Bryan F
Aug 18, 2015 02:28 PM
Leggman1
Aug 6, 2015 04:15 AM
