Blower motors interchangeable?? (AC vs non-AC)
Car: 88 Sport Coupe
Engine: 383
Just a quick question. I have an AC car (88 sport coupe) and plan to install an AC delete heater box. Can I keep my blower motor or should I get one with the delete box. Thanks
More ?'s to come, in the middle of the 305 to 383 swap!!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Blower motors interchangeable?? (AC vs non-AC)
JamesC
Car: 88 Sport Coupe
Engine: 383
I got my non ac heater box recently and the stock AC blower motor does line up. The vent hose hole might be off a bit but the screw holes do seem to line up...
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
You can make it work. I remember someone did it, and I think one hole didn't line up or something.
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
I believe it was something about the fan cage that didn't fit.
Engine: 4++,350 & 305 CIs
Yup motors will work but you have to swap to shorter fan cage.
There are two motors and two wheels:
Motor without AC is part #PM 102
Motor with AC is part # PM 111
(You'd think that if only the wheel required swapping, a single motor would be adequate for both boxes, but....)
Blower Motor wheel without AC is part #35602
Blower Motor wheel with AC is part #35601
Both motors were available at my local Autozone (didn't check for the wheels).
EDIT: A bit more info that might prove useful to the OP:
https://www.thirdgen.org/forums/body...ers-gotta.html
JamesC
JamesC
Car: 88 Sport Coupe
Engine: 383
Awesome, thanks JamesC for part numbers. I'll see if my autozone has it.
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Sorry for bring this back from the dead but ..... Are the wires different? What eles would be needed to do the a swap
Street Lethal
Aug 13, 2015 08:28 PM
