Normal to see bubbling in rad with cap off?
Old Jul 2, 2011 | 09:54 AM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Engine cold, started with the cap off. It bubbles like it's boiling. The higher the RPMs, the faster the bubbles swirl.
Old Jul 2, 2011 | 11:48 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Normal to see bubbling in rad with cap off?
thats an indicator of a blown head gasket...the "bubbling" could be air making into the water stream. it could also be some sort of internal block damage, but most likely a blown headgasket.
Old Jul 2, 2011 | 12:16 PM
Steel Armadillo's Avatar
Car: '85 Sport Coupe/Z28
Engine: N/A 350
Transmission: TH350
Axle/Gears: Factory 10-bolt w/3.08
^^ x2
Old Jul 2, 2011 | 01:14 PM
Mr Froman's Avatar
Exactly what I was thinking, checking compression in each piston now...what should they be at? Just did cyl. 1 and got 130.
Old Jul 2, 2011 | 01:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The value isn't as important as having them all the same.
Old Jul 2, 2011 | 01:46 PM
Mr Froman's Avatar
Okay. I know you're supposed to do it with the engine warm but I've already screwed up my hands enough with hot manifolds. I think it'll be okay doing it cold as long as I'm just looking for similarity in numbers rather than focusing actual engine compression.
Old Jul 3, 2011 | 12:43 PM
Mr Froman's Avatar
Can I pull out all 8 spark plugs and crank the engine with the 2 fuel inj. fuses pulled + ign. coil wire disconnected to check for coolant spitting out of the heads?
Old Jul 3, 2011 | 11:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not really
Old Jul 4, 2011 | 12:55 AM
Mr Froman's Avatar
Originally Posted by Apeiron
Not really
Alright what about putting 15 PSI on the cooling system using the a pressure tester and then trying after a few minutes to allow coolant to seep into the cylinders and THEN cranking with the plugs out to check for coolant spitting?
I pressure tested all cylinders. Six of them are at 150 PSI while cyl. #1 is 155 PSI and cyl #3 is 145 PSI. I'm going to pressure test those two again to make sure the numbers are right.
Other than a cylinder leak down test *i don't have an air compressor* I don't know what else I need to do to test for a blown gasket, or a warped or cracked head.
I started up my engine and revved it some and saw fresh splatter marks out behind my exhaust. My coolant spins and bubbles in my radiator when I rev my engine with the rad cap off.
I'm about to just replace the head gaskets and have the heads machined because I'm not sure how many more signs of a blown head gasket I can have. I'm not sure how else to check for "some sort of internal block damage" as mentioned by travis401.
Please - any input is appreciated.
Old Jul 4, 2011 | 12:59 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Better, but it still might not find your problem. You have exhaust gas at several hundred PSI getting into your coolant, you might not have coolant at 15 PSI getting into your chamber.
Old Jul 4, 2011 | 06:29 AM
Engine: N/A 350
Transmission: TH350
I believe what he meant by internal block damage would have to be a cylinder wall cracked through to a water jacket. Unless you have a 400 or a 350 bored considerably, I doubt that. Problem is with a cold compression check, the metal isn't warped like it is when the motor is hot, which is when your coolant is bubbling. If you have damage beyond a head gasket, I would think it was the head that is either cracked or the mating surface is pretty messed up. If the head is cracked, you would have an easier time finding it with a warm engine, as the crack will open up when hot.
This being said, it appears to just be the gasket. Replace it and machine the heads if you think they need it. AFTER A HOT COMP CHECK
Old Jul 4, 2011 | 09:01 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Last week on a trucks episode I saw this kit you can purchase where you add this blue fluid to a small plastic (clear) cylinder and then you place it over the radiator cap hole and let the gasses from the radiator enter the cylinder. On the show the blue fluid turned yellow indicating C02 which meant a leaking head gasket. I don't know where to get the kit but I saw it used on one of the weekend car shows. I think it was trucks.
Old Jul 4, 2011 | 09:10 AM
one92rs's Avatar
Car: SOLD!!!!!
since you already have a pressure tester. put the tester on the radiator and start the engine. watch the pressure and see what it builds to. it should go to about 15 psi in a normal rate of time. should take a while. if it builds quickly and keeps building then there is a leak. i usually put them on and put 5 psi on the system. then start the engine and see how fast it builds.
Old Jul 4, 2011 | 09:51 AM
travis401's Avatar
Car: 91 Camaro RS
Thats what I was refering to by internal block damage. which I also said isnt very likely, but it can happen. The only realy reason youd have a warped or cracked head is if it ran the car for a while AFTER it started over heating. most likely its just a head gasket that gave up the ghost.
Old Jul 4, 2011 | 11:08 AM
Mr Froman's Avatar
Agh...I guess I'll have to wait until tomorrow then. There's no way I'm going to try pulling plugs out of a hot engine without my gloves. Those exhaust manifolds are killers
And at this point am I just doing a hot compression check to see if I can find the weak spot? Because even when the engine is cold it runs funny with bubbles in the rad and if I'm replacing one gasket I'm most likely replacing the other while I'm at it...
Old Jul 5, 2011 | 05:53 PM
Mr Froman's Avatar
Not seeing bubbles in rad with belt disconnected
Old Jul 5, 2011 | 06:20 PM
one92rs's Avatar
Car: SOLD!!!!!
thats because the water pump is not turning. you need to take a picture of it.
Old Jul 5, 2011 | 06:40 PM
Mr Froman's Avatar
A picture of the bubbles? I have a vid if you want
I thought if I had a blown head gasket or warped or cracked head the exhaust gases would get into the coolant passages regardless.
The reason why I did it without the belt is because I was reading my book today. I was reading a section
"Diagnosing Head Gasket Failure"
Bubbles in the Coolant.
Remove the coolant pump belt to prevent pump operation. Remove the radiator cap and start the engine. If bubbles appear in the coolant before it begins to boil, a defective head gasket or cracked cylinder head is indicated. - don't have that problem unless belt is on.
I'm not sure how else to diagnose this. I have the problem when the engine is cold, so I pressure tested cold. Maybe a cylinder leakdown test?
Old Jul 5, 2011 | 06:49 PM
one92rs's Avatar
Car: SOLD!!!!!
show us the video.
Old Jul 5, 2011 | 07:53 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
I have had same exact prob for about a year. Though I don't drive. But motor doesn't overheat either. I have only broke one head gasket that I was sure of and it overheated very quickly. I am more thinking perhaps small cracks in a head . What heads you have? Stock?
Old Jul 6, 2011 | 12:14 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It will, but the bubbles will just rise instead of being entrained in the flow. They'll collect at the highest point available in the cooling system, and you'll get displaced fluid overflowing the filler neck, but won't see any bubbles for quite a while.
A leakdown test is the best way to diagnose a leaky cylinder.
Old Jul 10, 2011 | 11:20 AM
Mr Froman's Avatar
I have no air compressor at my house so no leak down test just yet. Bought one of those combustion testers with the blue fluid and it was pretty much blue the entire time but I think I did suck in a tad bit of coolant so I'm going to test again.
What is this hose?
Goes from under the throttle body to the heater control valve and down to a T where the red hose goes to the radiator and one down under the car
Attached Thumbnails Normal to see bubbling in rad with cap off?-0710011202.jpg   Normal to see bubbling in rad with cap off?-0710011202a.jpg   Normal to see bubbling in rad with cap off?-0710011204.jpg
Old Jul 10, 2011 | 11:37 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
heater hose and diverter
Old Jul 10, 2011 | 12:28 PM
Mr Froman's Avatar
Should that red hose be constantly shooting coolant into my rad? It's a steady stream, like a garden hose.
Old Jul 10, 2011 | 02:48 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yes, that's what it's for, it's routing water from the intake that goes either through the heater core or bypasses it and returns to the radiator
83 Crossfire TA
Jan 3, 2016 01:26 PM
tommy z-28
Oct 6, 2015 10:58 PM
customblackbird
Oct 1, 2015 04:30 PM
Stryker412
Sep 20, 2015 06:59 PM
TBRays98
Sep 6, 2015 05:05 PM
