Torque specs for cooling fan switch?
Old Aug 20, 2011 | 09:45 AM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Does anyone know the torque spec for the cooling fan switch on the passenger side head? Would the torque be different for iron or aluminum heads?
Kevin
Old Aug 20, 2011 | 10:46 AM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: Torque specs for cooling fan switch?
I use teflon tape and tighten til you feel it won't leak. app.10 ft-lbs or less
Old Aug 20, 2011 | 11:36 AM
Kwik89GTA's Avatar
Thats what I have always done, I was just curious. I have the 1989 and 1992 factory GM shop manuals but I didn't find the spec in there. The specs for EVERYTHING else is there..... the CTS on the intake is 108 in/lb and the knock sensor is 14 lb/ft..... but nothing on the fan switch or the temperature sending unit on the driver side head.
Kevin
Old Aug 20, 2011 | 11:38 AM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
I would definitely go easier on alum. threads
Old Aug 20, 2011 | 06:04 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'd use anti-seize maybe as well - aluminum reacts with alot of other metals and they chemically 'lock' together - never put steel into aluminum without anti-seize.
Old Aug 20, 2011 | 06:19 PM
Kwik89GTA's Avatar
I have always used Rector Seal teflon pipe dope. Works great. I also use it on head studs.
Old Aug 20, 2011 | 06:44 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
^Yes, pipe sealer is the way to go.
Old Aug 24, 2011 | 07:00 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
You really don't need pipe dope, teflon tape or ant seize, cause the fan switch is brass, and you need to keep the best connection possible.
Old Aug 24, 2011 | 09:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the pipe sealers also provide lubrication for the threads, to help them seat. You need to use something, or it will be very hard to seal the threads get everything tightened properly.
as you thread the parts together, the sealers disperse and you have metal on metal contact, no issues with electrical connection through any of that stuff.
dont use antisieze, the connection will leak. good teflon pipe dope is best, but the tape will work
Old Aug 24, 2011 | 09:15 PM
checkeye's Avatar
Its pipe thread not a bolt. Using teflon tape is not a good idea, the little bits of teflon get into the cooling passages and stuff. You DO need to use some sort of lubricant when you screw pipe threads into anything. Pipe threads are a friction, metal to metal contact seal. The lubricant allows the threads to slip and not gaul or tear as you tighten the sender into the head. Anti-seize is probably the best for aluminum heads. Only use enough to lightly coat the threads.
The electrical signal comes from the sender not a metal to metal contact with the head.
Old Aug 26, 2011 | 12:41 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
On a single pin thermal switch that opens and closes to ground it sure does need electrical contact to the head. Pipe sealer doesn't leak and provides good contact.
Old Aug 26, 2011 | 01:23 PM
I have iron heads, and since the switch was brass I installed it without anything, and it doesn't leak.
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
krisner89
Oct 10, 2015 06:03 AM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
