How Do I Remove The Front Air Dam ?
Old Aug 23, 2011 | 12:05 PM
LPUZ28's Avatar
Car: 1987 BLK/RD IROCZ28 5.7 LTR TPI 39K
Engine: 5.7 LTR TPI 1/12,000
Transmission: STOCK
Axle/Gears: STOCK
How Do I Remove The Front Air Dam ? Is There Somewhere To Hook A Tow Rope ? & No I Cant Just Look.. (curious? ask in personal email)..lol
THANKS!
LPU Z28
Old Aug 23, 2011 | 03:46 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: How Do I Remove The Front Air Dam ?
There are 6 ( IIRC )
10 MM bolts holding it to the lower rad support.
I hope if you're tow-strapping it you don't tear up the chin or bumper!
Good luck
Old Aug 24, 2011 | 12:35 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
There are two places for a hook under each side of the front end. The holes are a little elongated but you will see them and they will clear your plastic.
Old Aug 25, 2011 | 05:54 AM
LPUZ28's Avatar
Transmission: STOCK
Axle/Gears: STOCK
Good luck
Thank You t-top havoc!
I may as well say why I asked.. I parked my Z in the backyard for a couple days..was watering the lawn..hole in hose saturated the ground & IT SUNK!
3 tires were nearly 7 inches in the ground! I gave up digging and bought a 5650Lb Tow Rope/17000Lb BreakStrength-wrapped it around the upper frame/by the radiator I guess & to my Pathfinder. Put the Pathfinder in 4LO & she popped right out!
Thanks again!
Old Aug 25, 2011 | 05:58 AM
LPUZ28's Avatar
Transmission: STOCK
Axle/Gears: STOCK
Thank You abray1!
repeat msg:
Thanks again!
Old Aug 25, 2011 | 08:23 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Glad you got it out, but if it ever happens again I wouldn't hook it to that upper radiator support bar, its just a hollow thin piece of sheet metal! I would've taken out a signal light and went for one of the factory tie down holes, or take out the grille and wrap it around the K member and feed the strap through the bumper. There's a lot more strength in those areas.
Old Aug 25, 2011 | 02:07 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
"...was watering the lawn..hole in hose saturated the ground & IT SUNK!
3 tires were nearly 7 inches in the ground!"
Damn!!!! That's alot of water!!!
Old Aug 25, 2011 | 08:03 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
after removing it send it to me, the previous owner cut mine down to less than an inch in length. Basically too short to do it's job. I can only manage short trips at highway speed before the temp starts to climb to the point of overheating. If you arn't going to ship it to me make sure to keep it so you can put it back on when you're finished with whatever u need to take it off for. You probably already know this but our cars are bottom feeders, the way they get proper airflow through the rad at highway speeds is due to the air deflector which forces air upward from under the front of the car and through the rad. Sure probably won't ever notice it if you only drive around town in stop and go traffic, but it's defently needed for extended driving at high speeds since it is the only way to get airflow through the rad. (Cooling fans are useless at highway speed)
Old Aug 27, 2011 | 11:05 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
LOL call up classic industries man, they've got them for sale. I think Hawks sells them too. You got to have it! HAHA
Old Aug 27, 2011 | 12:38 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Yes, they are really easy to take off. If you need a replacement we have new original GM pieces available on our site for $37.95. Here's a link if you're interested.
http://thirdgenranch.com/-strse-958/...air/Detail.bok
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
3rdgenparts
Aug 8, 2015 07:09 PM
