water pump v6
Old Oct 23, 2011 | 06:32 AM
kc kid 1's Avatar
water pump v6
I just bought a 1992 v6 and the water pump must have got in a bind but the water pump pulley is gone look for one at a salvage yard but could not find one, will a v8 pulley work?? or same size v6 work?? or does it have to be a camaro v6?? thanks.......
Old Oct 23, 2011 | 10:31 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: water pump v6
Get the same diameter. Doesn't matter what it comes off.
Old Oct 23, 2011 | 10:35 AM
ex-x-fire's Avatar
Re: water pump v6
Might try a s10 that has a serp. system.
Old Oct 23, 2011 | 11:04 AM
kc kid 1's Avatar
Re: water pump v6
do you know what size it is because it was gone and I couldnt find it???
Old Oct 23, 2011 | 11:46 AM
ex-x-fire's Avatar
Re: water pump v6
Here's a 2.8L truck set up, looks like the pulley is more off set the the camaro pulley. The diameter is about the same as the p/s pump pulley.
Old Oct 23, 2011 | 11:51 AM
ex-x-fire's Avatar
Re: water pump v6
Nope, the s-10 2.8 has a longer water pump. Maybe the 4th gen 3.4s might be the same. Or try to get one from some one on here.
I see one on ebay 25 bucks or less.
Old Oct 23, 2011 | 10:33 PM
kc kid 1's Avatar
Re: water pump v6
I tried one off a s 10, and a v 8 and it would not fit due to hub on the water pump is to big to fit the puley.....
Old Oct 23, 2011 | 10:52 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Re: water pump v6
Is there not a parts store with a catalog anywhere near your house?
Old Oct 24, 2011 | 06:05 AM
ex-x-fire's Avatar
Re: water pump v6
It looks like an 87 up s10 pulley would, only if you change the pump also.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
