dual fan issue
Old Dec 16, 2011 | 05:36 PM
shinzon1's Avatar
Car: 89 camaro rs
Engine: carbed vortec 355
Transmission: upgraded T5
dual fan issue
i've got the single stock fan and an aftermarket pusher fan on my car. when i turn both fans on at idle the rpms drop about 400 rpm and the engine will die unless i feather the gas a bit. anything above 1200 rpm and it is fine. if i just use the pusher it does fine. no drop in rpm. has anyone ever had this issue?
Old Dec 16, 2011 | 07:45 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: dual fan issue
mech or electric fan?
Old Dec 17, 2011 | 07:51 AM
shinzon1's Avatar
Car: 89 camaro rs
Re: dual fan issue
electric. brand new alternator tested and working well. volt gauge does not drop more than a half a volt down to about 13 to 13.5.
Old Dec 17, 2011 | 12:43 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: dual fan issue
Look at a Zirgo fan. I am replacing my dual fan set-up with a single 16 inch Zirgo that puts out over 3000CFM.
Old Dec 17, 2011 | 01:03 PM
travis401's Avatar
Car: 91 Camaro RS
Re: dual fan issue
put a multimeter on the battery and turn the fan on and see what voltage the battery is actually at when that fan is on.
Old Dec 17, 2011 | 01:25 PM
shinzon1's Avatar
Car: 89 camaro rs
Re: dual fan issue
i'll check the voltage out tonight or tomorrow. will let u know.
Old Dec 18, 2011 | 03:20 PM
shinzon1's Avatar
Car: 89 camaro rs
Re: dual fan issue
ok. this is with the engine off. the floating was voltage was 12.61. with the aftermarket proform fan on the voltage was 12.21. with the factory fan it was 12.15. with both it was 12.00 even.
Old Dec 18, 2011 | 03:35 PM
travis401's Avatar
Car: 91 Camaro RS
Re: dual fan issue
if your multi meter able to measure amperage? im curious to see what kind of amps the stock fan is pulling.
try disconnecting the pusher fan and just run the stock fan and see if it drops.
Old Dec 19, 2011 | 07:17 AM
shinzon1's Avatar
Car: 89 camaro rs
Re: dual fan issue
not sure about the amperage option but i will check when i get back home. will check the fan out later today hopefully. thanks!
Old Dec 20, 2011 | 05:02 PM
shinzon1's Avatar
Car: 89 camaro rs
Re: dual fan issue
sorry. haven't had a chance to swap the fans yet. its been raining pretty hard here for the last few days. think its supposed to be a nicer day tomorrow.
Old Dec 20, 2011 | 06:51 PM
travis401's Avatar
Car: 91 Camaro RS
Re: dual fan issue
im thinking the stock fan motor is going out and drawing more amperage than it should, causing the issue at low rpm since the alt generates more power at higher rpms.
Old Dec 21, 2011 | 07:09 AM
shinzon1's Avatar
Car: 89 camaro rs
Re: dual fan issue
the motor is brand new. just replaced it a month ago. i finally got a chance to try it out. the stock fan on and the aftermarket unplugged. when stock one comes on it definately puts a load on the alternator but after 2 seconds of running it recovers easily. like it should. i went ahead and plugged both of them up. turned them on it dropped around 300 rpm but then after 3 seconds or so it recovered 200 rpm. i gues it has worked itself out some atleast. i haven't changed a thing. i think what i'm gonna do is hook one up to a thermostatic switch and the other up to a toggle.
Old Dec 21, 2011 | 09:10 AM
travis401's Avatar
Car: 91 Camaro RS
Re: dual fan issue
sounds like you need a bigger alt to run both fans.
Old Dec 21, 2011 | 09:11 AM
travis401's Avatar
Car: 91 Camaro RS
Re: dual fan issue
you shouldnt see any drop in rpm when the fan kicks on normally.
Old Dec 21, 2011 | 09:28 AM
shinzon1's Avatar
Car: 89 camaro rs
Re: dual fan issue
i've got an overdrive pulley that is supposed to increase the charging capacity about 30%. got it from March. i'll probably slap it on this weekend maybe and try it out to see if it makes a differance.
Frozer!!!
Jan 19, 2024 04:55 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Leggman1
Aug 6, 2015 04:15 AM
