upper ac condenser mount?
Old Oct 12, 2012 | 06:18 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, quick question. I'm installing a new AC condenser into my Trans Am after yanking out the old AC components a few years ago. Now I just can't remember if there's any sort of upper mount on the condenser. I know the bottom sits in those little rubber "mounts" that also hold the bottom of the radiator, but I can't remember what the top fits into, if there is anything.
Thanks!
Old Oct 12, 2012 | 06:29 PM
Engine: LB9
Re: upper ac condenser mount?
Nevermind, found a box full of old AC parts and found the upper rubber mounts.
Old Jun 8, 2018 | 03:47 PM
xbleedblackx's Avatar
Car: 88 Iroc-z
Axle/Gears: 2.77 9-Bolt
I gotta bring this thread back from the dead, I'm trying to go back together with the condenser/radiator assembly after having it torn apart since 2012 and can not for the life of me remember how the top of the condenser mounts in. Can anybody enlighten me? Pictures of the actual mount would be great! Thanks in advance.
Old Jun 8, 2018 | 05:06 PM
Drew's Avatar
The condenser slips into the rubber supports at the bottom, and then there's a pair of stubby rubber supports that go over the top, when the condenser is tilted forward into place little rubber barbs on the upper supports pop into the radiator support. The radiator further presses against the upper supports so they can't pop out.
Old Jun 8, 2018 | 06:57 PM
Car: 88 Iroc-z
I guess I've gone full retard. I didn't think any other mounting pads went into the radiator support other than the two for each side of the radiator. Anybody have a pic?
Old Jun 8, 2018 | 08:16 PM
Drew's Avatar
They be the ones in the middle.
Old Jun 8, 2018 | 08:32 PM
Car: 88 Iroc-z
Thats what i needed! Thanks Drew!
Old Jun 16, 2018 | 07:36 PM
RavingMadly's Avatar
Car: 85 IROC-ish
Axle/Gears: 9 bolt 2.77
I've been searching threads trying to find this for an hour. Thank God someone had an answer. Don't suppose anyone has a source for the upper mounts? My car didn't have a condenser when I bought it...
Old Jun 16, 2018 | 07:48 PM
Drew's Avatar
https://www.ebay.com/itm/82-92-Camar...s/192561433044
No relation to the seller, but I've bought a few things from him in the past. Most of them have been pretty good.
Old Jun 16, 2018 | 07:51 PM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
I should have some nice ones still in the garage.
Message if you are still looking.
Old Jun 16, 2018 | 07:54 PM
Car: 85 IROC-ish
Much appreciated.
Bubbajones_ya
Jul 6, 2024 08:32 PM
my86bird
Oct 23, 2015 12:20 PM
ynk1121
Sep 12, 2015 12:27 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
