mechanical fan or electric fan please help!
Old Mar 15, 2013 | 04:50 PM
1badgenesis's Avatar
hey guys i have a 85 z28 camaro with a aftermarket 350 in it, 3 speed th350 and 373 gears. when i first got the car is was overing heating, figured out the fans we'rent turning on. my buddy had a fan at the shop that was used in his nova its rated at 2800 cfm. i haved the fan wired to when i turn on the car which i love. car never over heats now but it does run a little hot on hot summer days. i also removed the thermostat, right now that its winter and if its under 50 out the car runs about 140 to 150.
now my question is over the summer that just pasted the car on hot summer days would run around 210 on city streets and 220 or so high way. its a little to hot for my liking lol now someone mentioned to me yesterday that a mechanical fan would be better for me? is this tru. i have one on my bronco and it stays at a nice temp. i was just wondering if i made the switch if it would help me run cooler in the summer
Old Mar 16, 2013 | 12:30 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: mechanical fan or electric fan please help!
it might run cooler with a mechanical fan-those can pull more air than any 12v electric fan at above idle RPM.The 2800 CFM electric fan should be able cool well at idle though-if it is actually delivering 2800 CFM(blade pitched right for airflow direction,ETC)If the mechanical fan is a clutch type in good working order,horsepower draw will be nil-non clutch types can pull a few HP at higher RPM while blasting a huge amount of air through the radiator.If you keep the electric fan,should be thermostat controlled so it is not pulling current off the alternator when the fan isn;t really needed.
Old Mar 18, 2013 | 11:47 AM
alright thanks for your help it was helpfull the car runs nice and cool at idle on hot days just not so much on the highway because of the 3speed
Old Mar 18, 2013 | 02:45 PM
Cosmik Debris's Avatar
If it's OK at idle and only get hots at speed I would suspect the air-dam under the front of the car. This deflector is critical for cooling.
Old Mar 19, 2013 | 04:38 PM
so i need to buy an air dam? i dont think theres anything under my car
Old Mar 20, 2013 | 05:17 AM
i just looked my car doesnt have anything under the front its all open lol
Old Mar 20, 2013 | 05:22 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Thirdgenranch & Hawks have them. Maybe get one from a u-pull-it.
Old Mar 28, 2013 | 10:30 AM
thank you
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
Johnoooooo
Sep 22, 2015 08:55 AM
