3.1 rad
Old Mar 16, 2013 | 07:42 AM
GotTurns's Avatar
Car: 1989 Camaro RS
Engine: 2.8 MPFI
Axle/Gears: Open 3.42
3.1 rad
I have used the search button but haven't had any luck. I am going to be doing a v8 swap in my car in the next coupple of months and the rad on my 2.8 is bad. i was wondering if i can use the 3.1 rad on the 2.8 so i don't have to spend more than i have .
Old Mar 16, 2013 | 07:45 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 3.1 rad
Yes IIRC the 3.1 Rad will work fine. Im unsure if the cooling capacity is the same. But the hoses will fit up correctly. T
Old Mar 16, 2013 | 10:07 AM
GotTurns's Avatar
Car: 1989 Camaro RS
Engine: 2.8 MPFI
Re: 3.1 rad
So the hoses get connected the same way as they are now and thanks for the replay
Old Mar 16, 2013 | 11:56 AM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: 3.1 rad
I thought the 3.1 radiator was the v8 radiator as well....
Not sure about Camaros, but my 3.1 has the upper hose connect on the driver's side, and 2.8s seem to connect on the passenger side in the pics I've seen. If that's the case, the 3.1 hoses should be all that's needed with it.
Elephantismo
Feb 13, 2019 12:51 AM
randy210
Oct 15, 2015 03:43 PM
tommy z-28
Oct 6, 2015 10:58 PM
customblackbird
Oct 1, 2015 04:30 PM
Stryker412
Sep 20, 2015 06:59 PM
