Radiator Air Dam, Worth it???
Old Mar 22, 2013 | 11:45 PM
Oddie65's Avatar
Car: 1986 G92 Z-28
Engine: '89 L98 (5.7 TPI)
Ok, so it's about 32 degrees outside and after about 5 mins on the interstate doing 65, my needle was reading 220, for my car thats very high for this kind of weather. In the summer that's about what it runs with the air dam on (That little black piece under the car that scrapes every damn thing you go over). I removed it a couple of days ago because I was really tired of it scraping on every speed bump, and getting out of my driveway, and any time I went from a flat surface to an incline. Do you guys think that temp is normal for it being so cold out, and do you think that air dam is a necessary piece?
Old Mar 22, 2013 | 11:53 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: Radiator Air Dam, Worth it???
Yes, it is necessary. Put it back on and see what the difference is.
Old Mar 23, 2013 | 08:48 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
The factory put it there for a reason.
Its a must have.
Old Mar 23, 2013 | 03:05 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
turn in at an angle and this will eliminate a lot of the scraping.
Old Mar 23, 2013 | 03:16 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
i dont have the air dam. its really not needed. The car runs at 210 on the highway. the city runs at whatever you have your electric fans set at
Old Mar 23, 2013 | 04:25 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
imagine what it would be on the hwy if you had the dam!
Old Mar 23, 2013 | 04:36 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
it really doesnt need to be any colder. 210 is a great operating temp for a 350. i get great power and close to 30mpg on the highway so i think i have it set up just right
Old Mar 23, 2013 | 05:22 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
The 1988 manual says that the computer will set a Code 14 if the temperature sensor tells it that the coolant temp in the V8 Camaro is in excess of 275 degrees for longer than two seconds.
Old Mar 24, 2013 | 04:20 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
200-220 is the "Factory" operating temp of our cars.
Old Mar 24, 2013 | 07:06 AM
nhgator's Avatar
Car: 1985 T/A
My car wouldn't run over 50 mph without it,temp would head for the redline.
Old Mar 24, 2013 | 11:33 AM
Oddie65's Avatar
Car: 1986 G92 Z-28
Gator, I think you have some cooling issues if you can't go on the interstate without overheating. I'll put it back on I guess, but man it gets annoying have to almost stop and creep over every speedbump and hill, haha. Thanks for the info guys!
Old Mar 24, 2013 | 12:14 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
New struts will get rid of about 98% of air dam scraping. I used to dread going over a short stiff speed bump because although it wouldn't rub going over the bump, the drop down after the bump would scrape the front end.......New struts made a world of difference.
Old Mar 24, 2013 | 12:18 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
If the car is running about 210* under low load on the highway imagine what temp it will get to if you ever put it under a load like say full throttle for 15-20 seconds. Yeah, then it won't cool down becuase it won't have enough air flow to overcome the heat saturation the block has.
Put the air dam back on and let the thermostat do its job of regulating the cars coolant temps to where its supposed to be.
Old Mar 24, 2013 | 12:22 PM
Car: 1989 GTA
I'm surprised that your car can handle Florida climates without an air dam. You have the same front end as me (later Firebirds having less opening than the Camaros, which only makes cooling worse)
It was 90° last week in Houston. Even with the 3 core aluminum radiator, both fans on, and the air dam on, the car still wanted to run 190° on the freeway.......The fans on our cars shut off at 40+ mph, making the cars rely solely on air flow to keep the car at temperature. Taking off the air dam removes the only thing we have to send that air into the radiator.
Old Mar 25, 2013 | 04:01 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
i agree
i agree on that to im in cali and with my last camaro i didnt have a air dam it would run on the hot side as soon as i put airdam on notice a drop in coolant temp
air damn is a must unless your running fans "Dual Fan" on constantly then you can prob get away with it
Old Mar 25, 2013 | 07:12 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
I wish I had never taken mine off...it got tossed along the years and now they're hard to find.
Old Mar 25, 2013 | 07:34 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
local junk yards or hawks
Old Mar 25, 2013 | 08:53 PM
A car will only run as cool as the thermostat allows in normal situations. If someone has a 195* thermostat installed then cruising on the highway no matter what the outside temp is it will run about 190* because air is constantly moving over the radiator. This assumes that its not so cold that the system can't even build any heat and saturate the coolant.
If its -20* out, well, getting to 190* would take quite a while.
Old Mar 25, 2013 | 10:50 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
you sure your gauge is accurate?
Old Mar 25, 2013 | 11:24 PM
Cooling 101.
The "coolant" is a storage medium for heat. Its circulated through the engine to keep the heat as evenly distributed as possible. When the coolant reaches a specified temperature a thermostat opens allowing hot coolant to flow into the radiator where the heat is transferred to the air.
As long as the heat generated by the engine does not exceed the cooling systems ability to dissipate it the temperature will never exceed the thermostats opening temperature by a measurable amount. This is because the thermostat will stay partially open allowing just enough coolant to flow through the radiator to keep it at the proper temp. A 195* stat fully opens by 195*.
Normally, the engines heat output is well below the cooling systems ability to dissipate it with a Air-Dam installed on a thirdgen. However, if you remove the air-dam you eliminate the forced airflow through the radiator. This means heat builds up in the system and the car will overheat at highway speeds because the heat generated by the engine exceeds the radiators ability to dissipate it with poor airflow due to the lack of a air-dam.
If you think you can build a fan system that can keep enough air flowing over the radiator without the air-dam then go ahead. But its just wasted horsepower and the fans will wear out that much more quickly.
With a 160* thermostat my LT1 NEVER got above that on the highway. And this temp I read from the datalogs on my laptop. The engine coolant was almost always at 159* or so on the highway.
Old Mar 25, 2013 | 11:49 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
That's kind of what they're made for. Put your air dam on and take bumps at an angle.
Old Mar 26, 2013 | 07:11 AM
Never had a issue with bumps, and many people on these boards have lowered cars and don't have issues with the air-dam.
But its kind of a required thing, especially with Birds as they have no nose openings.
Old Mar 26, 2013 | 08:06 PM
Dakota W.'s Avatar
I go slow over speedbumps and never have a problem, even with extremely worn suspension. My biggest problem is driveways, but taking them at an angle works wonders.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
87iroctheo
Dec 4, 2016 11:47 AM
krisner89
Oct 10, 2015 06:03 AM
Thornburg
Aug 27, 2015 08:28 PM
