Cost to have A/C refrigerant drained?
Old Mar 30, 2013 | 02:44 AM
Flightoficarus's Avatar
Hey all,
I know the best way to figure this one out is probably to just call some places, but I want to get an idea of what on average, you might pay. Not too expensive, I'd imagine?
I'm removing my A/C soon, and none of the parts stores around here seem to rent out tools for you to DIY. Sure, there's the illegal way, but environmental stuff aside, I'm gonna be working in a garage, and don't feel like getting blasted in the face or breathing in a bunch of the crap!
Old Mar 30, 2013 | 04:32 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Cost to have A/C refrigerant drained?
If it's a recovery only, cost will be minimal.
Old Mar 30, 2013 | 01:01 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
My AC hadn't worked in many years, I don't think it had more than a few psi in it, if any. Had yours been working or had you recharged it recently?
Old Mar 30, 2013 | 10:39 PM
To be completely honest, I've never even tried using the A/C since the car has t-tops, but I vaguely remember the seller either saying that it needed a recharge, or it didn't work very well back when I bought it.
Old Mar 30, 2013 | 11:07 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
If you get blasted in the face with it, you risk going blind. Refrigerant will freeze your cornea. Causes permanent damage. Safety goggles are a must. Even when just checking the pressure.
The labor on sucking refrigerant out of your car is zilch. It's just two hoses that screw onto your service ports. From there, it sucks it back into their machine. Back when I had my R-12 sucked out and vacuumed, it was a simple 30 minute labor charge. (I wanted them to run a vacuum on it for 30 minutes).
If all you want is for them to remove the refrigerant, you could probably slide any shop a $20 bill.
Old Apr 2, 2013 | 07:26 PM
So, I have one more question - Since I've never actually tried using the A/C, what if I went to go try it out, and it doesn't blow any cold air at all? Does that mean the system is empty, or at least low enough that I can safely remove it without having to take it somewhere to get drained?
I've done a bit of calling around, and haven't found a place willing to only drain it out (They will only do recharges - probably so they can charge full service price), and I work irregular hours (overnight), so I'd prefer to avoid having to take it somewhere shady that's only open during a time I'm normally sleeping if possible
Old Apr 2, 2013 | 09:03 PM
Joe Tag's Avatar
Not necessarily so. There is a pressure safety switch that cuts the compressor off when the pressure is too low. There may still be a good bit in there though. Any ammount released into the environment is not a good thing, as well as illegal. Though it is commonly done(even by certified technitians) Recovery is the only responsible way to do it.
edit: Try a residential HVAC company,they should have the recovery equipment.
Old Apr 2, 2013 | 09:30 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Note: Residential HVAC units don't use automotive type refrigerants. They won't want to contaminate their recovery equipment by mixing recovered refrigerants.
Old Apr 3, 2013 | 04:51 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Over the phone, your request sounded fishy so the shop just said they will only do a recovery and recharge. If you actually went there and explained what your are trying to do they would probably do it.
Old Apr 3, 2013 | 05:05 PM
bwiencek's Avatar
Car: 1984 TA - 17k orig miles
Engine: 355
Axle/Gears: 3.44 Dana 44 performance rear
Call and tell them you are doing a "full restoration" on the car or turning it into a "drag car" and need to have the A/C system evacuated before unbolting all the a/c components and so you just need the evac and not a recharge - that should make more sense to the phone jockey if you call a major chain or somewhere they have only a semi-knowledgeable service writer.
Bringing it by a smaller shop that does A/C service is probably the best way to get it done as you can explain what you're doing and like Reid said they'll probably do it for $20 or if it's got a lot of R12 in it they might know it's worth more to get free refrigerant to re-sell to someone later and do it for no cost...
Old Apr 5, 2013 | 11:48 AM
Good news/an update everyone!
Found a place w/a machine for R-12 refrigerant willing to do a recovery dirt cheap. Showed up this morning - Turns out the system was already empty! My guess would be that the PO drained it out and never got around to actually removing the A/C? Regardless, no charge to find out
I do have one more question though - When I remove it, I have to get a non A/C heater box to keep my heat/defrost, correct? I do live in western WA, where I will still want these things. If I went without the box for awhile for whatever reason, is the only other way to drive the car to bypass the heater core? Haven't digged into it much yet, just curious.
Old Apr 5, 2013 | 01:00 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
whatever a ball point pen costs
Old Apr 5, 2013 | 01:11 PM
Joe Tag's Avatar
Already empty, no charge... pun intended?
No it will work fine with no compressor or other A/C parts. Should leave the evaporator(part in the A/C box) just so it is sealed up.
jrdturbo
Mar 31, 2016 02:58 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
raymondandretti
Sep 27, 2015 06:43 PM
