ac unit
Old Feb 16, 2014 | 11:27 AM
patriots781's Avatar
Car: firebird 91
Engine: 350 5.7 small block
Transmission: turbo transmission
ac unit
The prior owner took my ac unit out I was jw how much a new one would cost and the best place to get one?
Old Feb 18, 2014 | 05:45 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Lost His Cool
If you want to do it yourself your parts cost will be approximately $600.*
If you want a shop to do it, their parts and labor will be approximately $1800.
Depending on how many parts the PO took.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Old Feb 19, 2014 | 09:21 AM
krazeefewl's Avatar
Car: 1991 Camaro RS
Engine: 305 will be LSX eventually
Axle/Gears: Borg Warner
Re: ac unit
I was in the same boat as you. The PO hacked everything off, cutting the A/C bracket in half and took the condenser/blower motor housing completely out and patched the holes with some knockoff dynamat. I got lucky and found a guy parting out a car and got everything but the A/C bracket for $200.
Old Feb 19, 2014 | 09:35 AM
Car: firebird 91
Re: ac unit
Wow I have the blower the heat works fine do I need a whole diff blower?
Old Feb 19, 2014 | 09:42 AM
krazeefewl's Avatar
Car: 1991 Camaro RS
Re: ac unit
No if your blower works and you have heat you are fine. What components of the A/C are you missing?
Old Feb 19, 2014 | 10:06 AM
Car: firebird 91
Re: ac unit
I'm not sure I think the pulley,ac compressor?
Old Feb 19, 2014 | 10:20 AM
krazeefewl's Avatar
Car: 1991 Camaro RS
Re: ac unit
If you have pictures we would be able to help a little more. How about the a/c lines, evaporator, condenser?
Old Mar 7, 2014 | 10:00 AM
Car: firebird 91
Re: ac unit
http://www.stockwiseauto.com/product...FU4aOgod2z0AyQ
Old Mar 7, 2014 | 10:02 AM
Car: firebird 91
Re: ac unit
http://www.google.com/#q=91+firebird...25884769197214
Old Mar 7, 2014 | 10:04 AM
Car: firebird 91
Re: ac unit
http://www.google.com/#q=91+firebird...78118007417016
Old Mar 7, 2014 | 10:05 AM
Car: firebird 91
Re: ac unit
So I would need at least those 3 things?
Old Mar 13, 2014 | 06:03 PM
Car: firebird 91
Re: ac unit
Old Mar 13, 2014 | 07:21 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: ac unit
Where are you? I (and probably others) have a complete set up I pulled from my '91 v6. If it's the same components and shipping is not crazy etc. I'd take $100 plus shipping to get rid of it.
Old Mar 13, 2014 | 07:34 PM
Car: firebird 91
Re: ac unit
Mass ill do that if you wanna pm me
Old Mar 14, 2014 | 07:53 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Re: ac unit
That's about the going rate I think. More people seem to be deleting AC than re-installing. I'm aslo re-installing as the PO had the AC removed to install an AC delete panel but the process wasn't completed before my buying the car. I picked up almost everything on here minus compressor (came with car) and condensor (thought it was in a box of parts with car for $100 shipped. AC box is in excellent shape as well with perfect factory sticker over blower motor and top half of box over evaporator core was new so it looks real nice. I didn't realize that I didn't have the compressor bolts though so need to locate a set.
Question I have is - when reinstalling a system, what parts should be replaced and what can be used for the system to operate efficiently? I have like three accumulators, however, they're as cheap as $13 on RockAuto. Is it best to replace? Will be using R134 and my brother will charge/check system at his work.
Old Mar 14, 2014 | 07:57 AM
Ed1LE's Avatar
Engine: 5.7, 5.0
Re: ac unit
BTW, V6 systems are different from V8 on serpentine cars. Compressor is on drivers side/alternator on passenger side on V6, opposite the V8 setup.
Old Mar 14, 2014 | 10:40 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: ac unit
I'm not sure of the v6/v8 differences and if the components are the same with different brackets. I found a ton of info and internet videos about replacing parts and doing R134 conversions but went with weight loss to auto-x the car.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
gord327
Oct 3, 2015 01:25 PM
ironbmt
Sep 27, 2015 06:00 AM
