Engine Oil Cooler - Factory Tube and Fin?
Old Sep 16, 2014 | 12:55 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I've never heard of this factory type of cooler mentioned here (see attached).
Did GM ever install a cooler like this on 3rd Gens?
The only coolers I've ever seen are the ones plumbed with engine coolant.
Old Sep 20, 2014 | 01:49 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Engine Oil Cooler - Factory Tube and Fin?
interesting!! and yeah, I have only seen the ones you mentioned. where did you turn that up, may I ask?
Old Sep 20, 2014 | 01:57 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Interesting. It does clearly indicate LG4, but not a vehicle line. Was LG4 used elsewhere (other than F-bodies), like Caprice, or pickups?
Old Sep 20, 2014 | 02:27 PM
Car: 86 IROC
Engine: 5.0 TPI
the PDF file clearly states the " F " car line. that's us right there. but I have only seen the oil to water design. no hope of ever finding one of these though. but dayum! I sure would like one of those for my 86 IROC!!
Old Sep 20, 2014 | 03:51 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
I found this when I was thumbing through a 1986 F-Body Assembly Manual.
It was probably drawn up but never put into production.
Old Sep 20, 2014 | 04:09 PM
Car: 86 IROC
Engine: 5.0 TPI
I have never understood why the engineers thought "cooling" the oil with hot anti freeze was gonna work. but ,hey what do I know.
Old Sep 20, 2014 | 04:41 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
id guess on the police cars.
Old Sep 20, 2014 | 04:49 PM
DynoDave43's Avatar
Oh, you mean those BIG BOLD LETTERS above the little ones I was reading? Missed 'em.
Old Sep 20, 2014 | 05:38 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Because it says "Awaiting Layout Approval" I'm guessing it wasn't approved for F Body. I ran that part number through the GM Part Catalog and it shows as a cooler used in 73-84 Blazers, pickups, and Suburbans. The part number changed to 12364237, but the illustrations I see online for that # don't look anything like what we see in the pdf you showed us. I'm no Parts guy so my trail goes cold there.
Edited
OK, so I did some more digging, I ran the Part Number for the bracket and it came up for a 83-85 F Body Export vehicles and shows the second cooler part number is discontinued, so maybe some of the F-Bodies got this after all.
Old Sep 22, 2014 | 11:44 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Works fine in my Express!! My oil temps dropped nearly 50*F with the factory style in-radiator cooler. They were pushing nearly 300*F on long hill climbs towing 6,500 lbs.
Old Sep 22, 2014 | 08:37 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Another needed item for our cars that GM didn't see the need to spend the little bit extra money on for mass production. I wonder if maybe it had to do with some oil conservation propaganda since oil would be running though the cooler and you would have to add more?
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Navy8125
Aug 21, 2015 09:32 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
