Where to put External Tranny Cooler
Old Sep 23, 2014 | 06:09 PM
Reddeath210's Avatar
So I recently purchased one of the famous 3 core aluminum radiator from Champion. I am currently putting my car back together.( engine was just installed). Now I want to install my new 3 core radiator, originally I was going to just use the tranny mount kits that connect to the radiator. But I was told to not due that to, leaves and dirt buildup over time. That would result in a hot spot. Any ideas on where I could mount one, would be great. Pictures would be even Better.
I was also thinking of getting a better tranny cooler, than the one I have currently, since I upgraded the torque converter to a 2800 stall speed, with lockup. I was looking at using a B&M supercooler, they seem to be a popular choice.
Any thoughts or suggestions on what to do would be greatly Appreciated.
This setup looked good to me, but idk if I we can do that on cars like ours, and it be effective. http://foohbar.com/magnum/frankencooler/018.jpg
Old Sep 23, 2014 | 08:42 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Where to put External Tranny Cooler
I have a B&M supercooler. unless the cooler has a fan, you're going to want to mount it in front of the radiator. Run the coolant through the radiator first, then the trans cooler, then back to the trans.
If the trans cooler has a fan, you can mount it just about anywhere.
Old Sep 24, 2014 | 12:57 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
yeah mine is mounted in front of the radiator. i run mine like this. tranny hot line to radiator in, radiator out to cooler in, cooler out to transmission
Old Sep 24, 2014 | 01:39 AM
But how do you guys have it mounted, do u have it directly mounted to the rad?
Old Sep 24, 2014 | 01:44 AM
yeah directly to radiator. using these zip-tie kind of things....
Amazon Amazon
Old Sep 24, 2014 | 02:38 PM
Amazon Amazon
But the issue I heard if u do it that way, is that it causes a hot spot due to leaf build up and such
Old Sep 24, 2014 | 04:35 PM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
I also heard that over time from vibration the pieces ran through the radiator can wear a hole in the tubes......
Old Sep 24, 2014 | 04:48 PM
Chevy2035's Avatar
Car: 92 Camaro RS
Engine: 355, Vortec heads, XE274 cam, 9.8-1
Transmission: 700r4 built for 800-900hp
Axle/Gears: 3.73 Gov Lock, Soon to change
I always make a bracket to mount them. I have had them cause leaks on alum radiators. Not often but once or twice in 10 years
put mine in next to the output shaft on a bracket from my Frame and Trans mount. Then made 2in tall fins and put 4 of down the length angled to catch the air and force it through the cooler. It works good, Trans temp stays around 180-200 depending how much i get on it, Thats with a built 700r4 (Fully manual Valve body and all the goodies)
Plan on getting it on the lift this weekend ill get some pic's of it and post when i do.
Old Sep 24, 2014 | 06:11 PM
Ozz1967's Avatar
Car: 1984 Trans Am
the B&M coolers come with the soft pieces that you mount between the cooler and the radiator.
I have two cross bars that cross in front of my radiator. I have mounted my cooler to them with zip ties.
You won't get any more hotspots with it than you will between your condenser and radiator. Just check it periodically and blow forced air in there to clean it out if you need to.
Old Sep 24, 2014 | 06:12 PM
Ozz1967's Avatar
Car: 1984 Trans Am
There are several members here who run them attached with the zip ties and have no issues.
I would, if you have the tools and knowledge, build your own bracket, or use the provided bracket parts to mount the cooler.
Old Sep 24, 2014 | 06:35 PM
Restrorob's Avatar
Car: 88 GTA
Have both and plan on do'n that, I'm not taking a chance with my new aluminum radiator.
Old Sep 25, 2014 | 03:28 AM
natdowson's Avatar
Car: 83 firebird 500 le
Engine: 350 chevy with 305 heads
Transmission: street/strip 700r4
Axle/Gears: chevy 10 bolt
I have found the best place to mount the external trans cooler just behind the front left or right grill opening if you have open grills it receives the coolest air directly to it and all you have to do is cut some rubber strips and drill 3 to 4 mounting holes in the body and bolt it up really the best place for it I spent hours under the car trying to find the best spot and found it I will post some detailed pics of were i have mounted it.
Hope this helps.
Cheers Nat.
Old Sep 26, 2014 | 06:23 PM
natdowson's Avatar
Heres a pic of where I have mounted the cooler.
The cooler is mounted just behind the grill opening, this position works well if you have open grills, in the pic you can see the light coming from behind the cooler this is the grill opening. It is quite hard to describe where it is so theres the pic if you go under the car you will be able to piece it together by using the picture as a guide. Heres how I run the line trans- hot fluid->radiator top in->radiator bottom out->trans cooler in-> trans cooler out-> back to trans deliver the coolest fluid back to the trans. Sorry about the pic bit hard getting under there to take it, the bottom of the picture is actually facing the front of the car the cooler is mounted with the pipe fittings facing up.
Do hope this helps other 3rd gen firebird owners. Any questions just ask.
Cheers Nat.
Old Sep 28, 2014 | 03:48 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
When I was new to building/working on my Camaro I bought this 12.5" x 17"
engine and transmission oil cooler that is just large enough for my 14" "primary" puller fan that comes "on" at 190* (now adjusted to 180*).
The engine oil cooling aspect is controlled with a sandwich adapter that only allows the engine oil to flow at 180* where the trans cooler runs all the time.The Transmission lines are ran the same as natdowson's .
Link = http://www.summitracing.com/parts/der-15903
Then there is a 16" pusher fan in front as a backup coming on at 200* with a 180* thermostat. Its such a tight fit it only needs zip ties as a precaution.
Both fans are being run by adjustable , temperature controlled switches.
I'm not promoting this axillary cooler installation because I can see where mounting it in front with a super cooler is a better option.
I would like to use a infrared temp. gun on the return line when its hot just to see where I'm at.
Any way here it is. =
Old Sep 28, 2014 | 04:13 PM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
I've got mine in front of the condensor mounted with the Summit kit, basically some Zip ties with spacers. However, read this....
http://www.hotrod.com/feature_storie..._transmission/
I'm going to end up redoing mine later on.
Old Sep 28, 2014 | 06:15 PM
Engine: TBI,5.0
Its been 8 years since the installation and I thought that was good but I'm willing to re wrought it ,moving it in front.
Mount a larger puller on the Radiator .
My setup works great for the coolant and now that I have reset the the axillary coolers puller fan to 180*,and the pusher to 190* that will have to do for now.
Old Sep 28, 2014 | 07:15 PM
Night rider327's Avatar
Car: 1988 Camaro
Here's pics of how I did mine.
Elec. fan mounted to engine side of rad.
2 trans coolers mounted/zip tied to the X cross braces in front of rad.
That was done 9 years ago and been working great since
Attached Thumbnails Where to put External Tranny Cooler-picture-406.jpg   Where to put External Tranny Cooler-picture-412.jpg
Old Sep 28, 2014 | 08:16 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Mine is like the one on the right side, but it's really too fat to put "behind" the bracing, without having the bracing rubbing against the cooler anyway.
Old Sep 29, 2014 | 12:57 AM
Car: 1988 Camaro
If yours is the super cooler (like mine on the right) then it won't hurt for the braces to rub against it. These are not the the tube/fin coolers which has the thin alum. fins on the thin alum. tubes that the ATF passes through.
The super cooler has thick, heavy outside with thicker tubes made into the cooler.
Hard to see in my pic cause of the angle, but the brace is touching the top of my super cooler. In fact I have the zip ties pulling it against the braces
Old Sep 29, 2014 | 09:06 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Mine is a supercooler and you're right, the thing is built like a brick. I may see if I can space it out a bit. I just prefer things not to rub together if it can be helped.
Old Feb 14, 2016 | 06:09 PM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Do you have to use a separate cooler for the transmission ??? ive just bought a 3 core champion rad to replace my stock one as the car runs a little on the hot side for my liking so im trying to bring it down a bit.
obviously the transmission lines just screw into the radiator to be cooled, and it looks like the champion rad has the some holes in it as i had a peek inside the box the other day when it was delivered.
Old Feb 14, 2016 | 07:25 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Only if you run a performance auto trans. Also for cooling look at having your fans turn on sooner.
Old Feb 14, 2016 | 10:50 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
B&M supercooler.Probably not the most efficient spot, but it works & didn't want to add more bulk to the radiator area, plus i have aux fan there already.So I used area under the battery.Made a bracket to resemble the plastic shield, cut the center out.Later I added an air scoop.
Old Mar 12, 2016 | 02:56 PM
90HSR406's Avatar
Car: '90 RS, UH-60M
Engine: HSR'D 400
Transmission: TCI POS DONT BUY TCI!!!
Axle/Gears: Three2three
I just mounted my super cooler with fan last night. I bought the cooler 2006. (Only took me 10 years to actually do something with it lol.) I mounted mine in a similar way 84 1LE did, but I have a bit of an angle to it to possibly increase efficiency. I don't have any engine cooling issues with my 400 and champion radiator, so I didn't want to cut any of the ducts in front of the radiator to make this fit. This seems like prime unused real estate. We shall see how it works. I still need to run the xmsn feed and return lines, and refine the mounts and hardware.
Attached Thumbnails Where to put External Tranny Cooler-img_6071.jpg   Where to put External Tranny Cooler-img_6073.jpg   Where to put External Tranny Cooler-img_6077_2-2-.jpg
Old Mar 12, 2016 | 06:50 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Nice work, good thing you waited.This is the air scoop I made.It actually help drop the temp about 15-18*
Old Mar 12, 2016 | 07:16 PM
90HSR406's Avatar
Car: '90 RS, UH-60M
Engine: HSR'D 400
I like the scoop idea. It looks good. I may have to fiddle with some metal and see if I can make something like that work on mine. I also thought about making a duct on top to smooth out the "downwind" side.
Old Mar 14, 2016 | 03:21 AM
Engine: TBI,5.0
Honestly,the more I think about it.
A transmission cooler with a fan mounted on it that ran while the car was running sounds best. In any situation.
My car sees a lot of city driving, stop light to stop light. Hard to get much of a breeze going.
I can set mine fan to come on at 100*. I think I will.....
wetnose
Jan 17, 2007 12:31 PM
hitman
Jul 18, 2006 12:42 PM
Knyghtmare
May 30, 2006 05:13 PM
ChevyRacer
Jul 28, 2005 08:23 AM
supermaxxbasher
Jul 9, 2004 02:57 PM
