Part Identification. help please!
Old Mar 17, 2015 | 11:44 AM
corey8084's Avatar
Car: 1991 Pontiac Firebird Formula
Engine: 5.0 V8 TPI
Transmission: T-5 5 Speed
I was removing what looked like radiator hoses from a plastic peace (I say looked like because the hoses ran into the dash) that I've pictured below. While doing this, the hoses did not exactly separate from the plastic peace very well and the hoses decided that they just could not part with the nipple. so now I have this plastic peace that I'm pretty sure I probably need it in one peace.
I'm asking here before I go to any parts store because I don't have a lot of confidence in their ability to identify it. If you need more/better pictures, please let me know and I'll attempt to comply.
Old Mar 17, 2015 | 11:57 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Part Identification. help please!
Heater control valve......vacuum controled to allow coolant flow to the heater core
about 20 bucks
Old Mar 17, 2015 | 11:59 AM
corey8084's Avatar
Engine: 5.0 V8 TPI
and this is why I love this site! thank you so much now to see if any local part stores would have that.
Old Mar 17, 2015 | 12:20 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Advance, O'reillys, Auto Zone all should have it
Old Mar 17, 2015 | 01:29 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
In the future, when removing hoses, if the old ones are really stuck on, it's better to cut them off. Use a utility knife, and cut through enough of the hose that you can peal it off, without undo stress on the other parts of the cooling system (this valve, radiator, heater core, etc.). But do not press so hard that when you cut through, that you cut into the part underneath. This will help avoid damage to those parts. Particularly the heater core, which is a PITA to get to if you crack a soldered joint inside.
Old Mar 17, 2015 | 03:45 PM
corey8084's Avatar
Engine: 5.0 V8 TPI
thanks for that bit of information. I'll remember for next time, hopefully I don't run into too many problems with that but I'm not getting my hopes up here. thanks guys
Old Mar 17, 2015 | 04:05 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I do that every day with the pumps I work on
Old Mar 17, 2015 | 07:12 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally Posted by Bob88GTA
Heater control valve......vacuum controlled to bypass coolant flow to the heater core and direct to the radiator.
Old Mar 17, 2015 | 07:15 PM
corey8084's Avatar
Engine: 5.0 V8 TPI
I see that you've altered his syntax a bit. I'm assuming the bypass is to prevent any coolant making it's way to the heater core so that it can heat up more quickly? similar to the way the thermostat works?
Old Mar 18, 2015 | 05:36 PM
deadbird's Avatar
Engine: TPI 305/ v6
When you slide the temperature all the way cold, it opens a small valve on the hvac controls. This applies vacuum to the divert valve, bypassing the heater core. Anything but full cold, there is no vacuum applied.
Presumably, this to assist the cooling efficiency (effect?) of the a/c.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
