Cooling Fan Won't Turn On
Old Jul 26, 2015 | 03:15 PM
MustangBeater20's Avatar
Car: 1991 Camaro RS
Engine: Built TBI 350
Axle/Gears: 3.42 Posi
On my 1991 RS, I have a swapped 350 and the cooling fan won't turn on. I replaced the connector and the switch on the motor. However, when the AC is on, the fans kick on! Anybody know what it is?
Old Jul 26, 2015 | 08:47 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Cooling Fan Won't Turn On
There is a fan control switch in the passenger head by the #6 cylinder just in front of the dip stick. This controls when the fan turns on.
Make sure it's hooked up. If it isn't, that's probably the problem. If you hook it up and it still doesn't turn on when the3 car gets up to temp, disconnect the wire and ground it to chassis ground with the key in the "run" position but the car not started. If the fans turn on, then you have a bad switch. If they don't, the relay is bad (but the switch may still be bad). Replace the relay and try again. If it stilldoesn't turn on when hooked up, but does when grounded then the switch is bad.
We know the power cicuit and the fans themselves are good since the fans turn on with the AC.
Old Jul 28, 2015 | 09:15 PM
Car: 1991 Camaro RS
I grounded the wire and still no fans. I will get another relay and try it.
Old Jul 29, 2015 | 11:58 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The fan turns on, you already know the relay is fine. The problem is somewhere in the wire from the fan switch to the relay if grounding it doesn't make the fan turn on.
(TBI is single fan Ozz )
Old Jul 29, 2015 | 05:31 PM
Ozz1967's Avatar
Car: 1984 Trans Am
On my carbed car with electric fan, my switch tested good but the fan wouldn't turn on even though it would activate with the AC. Replaced the relay and it fixed it.
Maybe it's different in TBI cars?
Old Jul 29, 2015 | 05:49 PM
deadbird's Avatar
Engine: TPI 305/ v6
Interesting to note. The 88+ years did get a relay type change and some minor wiring changes. Might be part of it, never know with gm...
Everything for turning the fan on, on a '91, ties to the fan relay coil ground though. Oddly, TBI is not an ecm controlled fan.
Old Jul 29, 2015 | 09:39 PM
Car: 1991 Camaro RS
Did I ever metion that the temp gauge works?
Old Jul 29, 2015 | 10:09 PM
deadbird's Avatar
Engine: TPI 305/ v6
That has nothing to do with your fan.
Old Aug 1, 2015 | 06:24 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
May have helped me OZ I have an 86 with the same problem.
Old Aug 2, 2015 | 09:29 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Let me know!
Old Aug 2, 2015 | 12:30 PM
Achilless's Avatar
Car: 89 trans am
Engine: 383
I have the exact same problem. I get 12 v at the relay, the wire going to my fan from the relay works, when I turn the car on I get 12 v on the other small wire. The green wire with a white strip will turn the fan on when I ground it off the relay. Looking into it today why its not being activated.
Old Aug 2, 2015 | 02:58 PM
Achilless's Avatar
Car: 89 trans am
Engine: 383
Ok so I don't see any other fan switch like people are talking about. I have a temp switch screwed into the drivers side that works great. Then the other coolant switch is on the top of the intake by the radiator intake. This switch has 2 wires going to it with around 5 v reading. I jumped that switch and still no go (motor was cold).
When I ground the green / white wire on the relay the fan kicks on. I traced it back to the computer. Cant I just run a jumper off my gauge temp switch to my relay??? Will this mess anything up? Help Help
Derick15
Sep 17, 2016 05:28 PM
TheExaminer
Aug 19, 2015 10:07 PM
ZsTransAm
Aug 11, 2015 07:30 PM
BrianI
Aug 9, 2015 11:52 AM
Leggman1
Aug 6, 2015 04:15 AM
