Broken LT1 water pump bolt
Old Aug 4, 2015 | 01:56 PM
bigcheeseburger's Avatar
Car: 1992 Camaro rs, 1988 Iroc
Engine: 305 TBI
So today has been hell. Ive broken the 4" bolt on the waterpump I knew it was going to break when I felt how hard it was to turn them. I've tried welding a nut to it but it just broke right off, then I tried drilling and using a step out. Well let's just say that was a very bad idea, the step out instantly broke and now I can't drill threw the hard material the step outs made of. I've tried heating the bolt up, vice grips, everything! Does anyone have a idea what I can do before I have to bring it to a machine shop?
Old Aug 4, 2015 | 02:04 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Broken LT1 water pump bolt
I used these to take out a waterneck bolt that the head broke off.Tap with a hammer, add socket and ratchet to it, and turn. Lube up with PB Blaster first. Couldn't believe it. IT WORKS! Only if you have 1/2" of threads sticking out
Amazon.com: Irwin Industrial Tools 394002 Bolt-Grip Expansion Set, 5-Piece: Home Improvement Amazon.com: Irwin Industrial Tools 394002 Bolt-Grip Expansion Set, 5-Piece: Home Improvement
Old Aug 4, 2015 | 02:05 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Advance auto has them in stock for 28 bucks
Old Aug 4, 2015 | 02:08 PM
Engine: 305 TBI
Thanks for your response. Ill have to give it a try. Only bad thing is I have about a little less than a half inch sticking out and its very stripped up from using vice grips to turn it
Old Aug 4, 2015 | 02:12 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I think 1/4" is all you need. it grips as soon as you stat ratcheting it out. The harder you try, the more it bites into the stud. It's a really beefy set. I thought for sure I was gonna break the tool, but it kept biting and turned the stud right out. Just soak it good for a while.
Old Aug 10, 2015 | 01:17 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
put the vise grips away and put a pipe wrench on it... get it nice and hot, then use the pipe wrench to put even pressure on it- don't jerk it at all or hit it with a hammer or anything.. if it won't budge, then get it nice and hot and quench the bolt with a real penetrating oil (i like PB Blaster, myself) and not WD40 because that stuff is useless for anything more severe than a speaking bedroom door hinge.. then put the pipe wrench on it as soon as you can and spin that thing out... it works on exhaust manifold studs that have been together for 40+ years so a 20 year old water pump bolt will be nothing..
Old Aug 10, 2015 | 04:15 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Here's why you soak the bolt with PB Blaster as suggested.
Spray it a few times and let do its job, even over night would be good.
Video link =
Old Aug 10, 2015 | 01:12 PM
novaderrik's Avatar
Car: 86 Camaro
the heat- even from a propane torch- makes the PB wick into the threads immediately instead of waiting over night... i know when i'm fixing something, i prefer to get it done and not have to wait hours if i don't need to..
one detail that i left out of my last post: keep the heat in the surrounding metal as much as you can- you are trying to get it to expand away from the bolt and break the bond. also, keep the pipe wrench as tight up against the surface of the block as you can to keep the torque from just twisting the bolt off.
Old Aug 11, 2015 | 11:40 PM
Engine: TBI,5.0
I guess if he can weld on it he can use a torch also.
Old Aug 12, 2015 | 07:23 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Did you try these yet???
Old Sep 17, 2015 | 02:00 PM
Engine: 305 TBI
I did get those bolt extractors, but I didnt even open them up lol. I got it with a big torch (oxygen and acetylene) propane didnt get it hot enough. Sprayed some pb blaster got it cherry red then turnt it out with a vice grip. Thanks everyone for reponding. Big help!
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
