What is the second mark on the gauge?
Car: 92 Z28 Camaro
Engine: 355 TPI
Axle/Gears: 10 Bolt 2.73
This may sound like a dumb question (and it probably is), but out of the four quarter marks on the coolant temperature gauge, what temperature is the one between the 100 and the 220? My car usually doesn't even make it there, that's why I'm wondering. The only time it will is if I'm at a light for a long time or otherwise moving very slow. That's with neither of the radiator fans turned on too. I have a 165 tstat. Yes, 165, not 160.
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: What is the second mark on the gauge?
Midway between 100 and 220 is 160.
The gauge is not linear, so it's not strictly accurate to just divide that range in half like that.
As you will notice, the low end is 100; the middle is 220, i.e. it takes 120° to go the 1st half of the gauge; but the high end is 260, meaning it only takes 40° to go the other half.
The sensor is DEFINITELY not linear. It's more of a log curve. But the gauge itself isn't linear either. (speaking strictly as a mathematician) I don't think it's realistic to even try to calculate a transfer function for the whole system.
Although I've never measured it, I'd estimate the "¼" mark at closer to 175°.
When it gets to that point hit your thermostat with a infrared thermometer. You'll know for sure that way.
Car: 92 Z28 Camaro
Engine: 355 TPI
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
As mentioned ,the only way to know how hot or cold your car is actually running is with a Inferred laser temperature gun.
Compare the reading from the Thermostat housing to the gage to see how far off it is.
= http://www.harborfreight.com/catalog...ed+Thermometer
Or a shop can do it usually for free. Its a 30 second job.
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
My car with a 180* thermostat sits just above the first mark, so Sofa may be correct-or-close...
Car: 92 Z28 Camaro
Engine: 355 TPI
That is where my car usually sits with only one radiator fan on. With both on it gets slightly colder.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
My 89, that tick is 195-200.
I believe my 91 is also similar temp range
Car: 92 Z28 Camaro
Engine: 355 TPI
That would make sense though because now that I think about it, it sat right around that line all the time when I had the 195 in it when I got the car.
Car: 89 Iroc-z
Transmission: TH400
Yup i think you are in the 170 range based on that pic. When my car is about there, its 175's or so
Car: 92 Z28 Camaro
Engine: 355 TPI
Chris Luongo
Aug 23, 2016 08:58 AM
'91CamaroRS
Nov 25, 2015 08:31 PM
