Temp sensor questions
Old Dec 25, 2015 | 09:31 AM
racereese's Avatar
Car: 1987 irocz28
Engine: 305 tpi
Transmission: t5 5 speed
Axle/Gears: GU4 3.08 g80
Ok i want to make sure i understand this area. My fans werent turning on so i ordered part#ts147 right?
The othere question i have is does the sensor that goes to ecm does that control the gauge in the dash too? I ask because i started throwing code 45 i have read on here to make sure its not the sensor because if it continues to read cold it will use to much fuel. My guage works inside the the car.
Old Dec 25, 2015 | 10:59 AM
Re: Temp sensor questions
That switch should at least work. Not sure about its temp.
No the gauge and ECM do not use the same sensor. The gauge doesn't use a "sensor" at all. It uses a sending unit, in the driver's side head between #1 & #3 plugs. The sensor for the ECM is at the front of the intake manifold.
Old Dec 25, 2015 | 02:58 PM
racereese's Avatar
Car: 1987 irocz28
Engine: 305 tpi
Thank you
Old Feb 22, 2016 | 02:18 AM
92RSUtah's Avatar
Car: 1992 Camaro RS 25th anniversary.
Engine: 3.1L V6
Transmission: 5 spd Manual
I've recently replaced my fan relay and it seems that it only comes on when the car is over heating. It looks like it does not come on as it is designed to, once the AC is turned on. Is that correct or am I doing something wrong.
Old Feb 22, 2016 | 06:53 AM
Probably...
Incorrectly identifying normal behavior as "overheating"; and/or, needing a new radiator cap.
Logan Bryant
Dec 16, 2015 11:32 AM
123pugsy
Dec 6, 2015 09:54 AM
DemonYusuke
Nov 15, 2015 12:13 PM
bbsr72
Nov 13, 2015 08:21 AM
cowboysfan20
Nov 5, 2015 12:46 AM
