Options for coolant resevior.
Old Sep 1, 2016 | 10:36 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Just curious what people are running for coolant over flow's in their cars. I dont want the big bulky stock one, dont want to run a 4th gen (Intercooler is going there soon) and im not sure how much space ill have between the radiator and the belt setup with the blower. Any input/pictures is welcome!
Old Sep 1, 2016 | 11:51 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Options for coolant resevior.
Unit from an Explorer. It holds both the coolant and washer fluid in one container. Mounted on driver's side up tight with the radiator support. I don't have any pictures but it has been mentioned on here before.
Also seen some people make their own out of PVC. Too much hassle for me though. PVC one is on here as well.
Old Sep 1, 2016 | 12:24 PM
Car: 86' IROC
Axle/Gears: 3.45
I just want something small and clean. Starting to wonder if i can find a stainless water bottle and stuff it between the battery and the radiator
Old Sep 1, 2016 | 12:46 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
You can get a small overflow setup from Summit Racing. They're pretty compact and can fit anywhere.
https://m.summitracing.com/parts/sum-300103
Old Sep 1, 2016 | 12:51 PM
3rdgenmaro's Avatar
Car: 88 IROC
Here is some pictures of the explorer setup. Cheap, clean, and simple.
https://www.thirdgen.org/forums/body...id-bottle.html
Old Sep 1, 2016 | 02:42 PM
Car: 86' IROC
Axle/Gears: 3.45
Looks like a nice install, But that space is occupied for me. Gonna have intercooler pipes through there this winter too.
Old Sep 1, 2016 | 03:57 PM
3rdgenmaro's Avatar
Car: 88 IROC
Id rather have your setup!
Old Sep 1, 2016 | 04:23 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
There are various GM vehicles w/ washer bottles mounted between the fender/batt tray that can be made to work.Some are pretty compact too.I was looking at a lot of them before I ended using the 4th gen piece.
Old Sep 1, 2016 | 05:44 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i've been using a small gatorade bottle for years, lol.
i do have a plastic summit one still in the box. just never got around to mounting it.
Old Sep 1, 2016 | 06:57 PM
siuol's Avatar
Car: 1987 Firebird Formula
Engine: Carbureted - 305
Hi, This what I use. Its from a 2007 Mercedes. Got it new from Ebay for 20 dollars.
I removed the charcoal canister and window washer container and re-located the radiator overflow to the drivers side. Hope this helps. Work great.
Louis
Old Sep 2, 2016 | 09:49 AM
Car: 86' IROC
Axle/Gears: 3.45
I ordered a stainless steel bottle bottle last night - 3" wide by 8" tall and holds a pint. Im gonna see if i can tap it and put a fitting on the side of it then mount it next to the radiator.
Old Sep 2, 2016 | 11:58 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Bingo. I mounted mine on the metal support (that the hood latches to) between the radiator and bumper.
sahlomonic
May 11, 2016 12:33 AM
GXP
Wheels and Tires
Apr 23, 2016 09:44 PM
kitt23
Apr 13, 2016 12:38 PM
2012sergen11
Mar 25, 2016 12:08 PM
omarcamaro
Wheels and Tires
Mar 20, 2016 04:47 PM
