Air Deflector Vs. Air Dam
Old Mar 11, 2018 | 05:28 PM
80smtn's Avatar
Car: 1986 Custom Convertible Trans Am
Engine: 305 Carb
Hi All, I have an 86 Trans am with what Hawks refers to as a front Lower Deflector. My front Lower Deflector is a long piece of flexible plastic that extends around the front of the car. I do not have any other cooling items under the car and am wondering if i need both my deflector and what Hawks is calling the "Lower Air Dam" My engine bay gets very hot. Thanks in advance. John
What i currently have
what i don't have. Do I need to add this?
Old Mar 11, 2018 | 06:16 PM
Drew's Avatar
Re: Air Deflector Vs. Air Dam
The 3 piece is a later service part to replace the one pictured above.
Old Mar 11, 2018 | 06:22 PM
80smtn's Avatar
Engine: 305 Carb
Thanks Drew. Do you think replacing my original wrap around with the 3 piece would make much of a difference in keeping my engine bay cooler?
Old Mar 11, 2018 | 07:25 PM
Drew's Avatar
As long as you have one or the other you should be fine. The change was made mostly to reduce costs and complexity.
Old Mar 12, 2018 | 07:46 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Did they ever use the 3 piece in production, or is that a service only part?
Old Mar 13, 2018 | 07:13 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The top one is for 85-90 birds without ground FX (base & formula birds) and is just the lower of 4parts.
IIRC, 91-2 have a different 3-5 piece style like the lower and there are 4 versions from 85-90 (2 types) 91-2 (2 types)
Old Jul 19, 2018 | 06:03 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
the air dam, I purchased this for my Formula to replace the one piece factory unit.
The middle main piece fits perfect but the other pieces don't fit to well so I just left them off.
Old Aug 18, 2018 | 11:03 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
my 87 trans am with ground fx uses that same wrap around air dam somehow it disappeared after my son owned it it started overheating at higher speeds say 40 and up- and was fine below that
it creates negative pressure behind it to help draw air through the radiator I was able to locate one years ago no more overheating
pontiacsteve
Jun 13, 2019 01:11 PM
FloridaZeke
Exterior Parts Wanted
22
May 30, 2013 08:52 PM
seanof30306
Exterior Parts for Sale
Aug 4, 2010 11:27 AM
FloridaZeke
Nov 22, 2009 09:39 AM
