Secondary Fan Switch
Old Apr 10, 2018 | 07:10 PM
rottweiler68's Avatar
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
Need some help....Have ‘89 Iroc,350 TPI, with dual cooling fans. Trying to find the coolant fan switch between cylinder 6 & 8. Applied 12v to broken wire that obviously came off the switch and secondary fan motor works fine, but can not find the broken switch location for the life of me. This is what I find, looks like a plug or the fan switch broken off?
Old Apr 10, 2018 | 07:19 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Secondary Fan Switch
That’s a pipe plug!
Drew's Avatar
Thats a plug. If the switch were broke off, you'd still have the hex body used to crank the thing in. Remove plug, screw in switch.
Car: '89 Iroc
Engine: 383 TPI
Thanks guys, will figure out the size of this stupid plug and get the switch!
Old Apr 10, 2018 | 07:28 PM
Engine: Lb9
Transmission: M20
Some are 3/8 so you can use a 3/8 extension and ratchet.
Old Apr 10, 2018 | 07:30 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/cool...ches-part.html
Sw555 is a good choice
Old Apr 10, 2018 | 09:40 PM
Car: '89 Iroc
Engine: 383 TPI
Sounds good thank you. Tried getting the 3/8 in there and couldn’t do it, seemed a bit too big. Going to pick up a 5/16 tomorrow.
Old Apr 11, 2018 | 06:39 AM
Looks like someone has replaced the heads, and didn't bother to remove the plug so they could put the switch in.
The other head has the temp gauge sending unit in that same hole. Before electric fans, the driver's side head always had the sending unit, and the pass side one got plugged.
Old Apr 11, 2018 | 07:07 AM
Car: '89 Iroc
Engine: 383 TPI
That’s possible but by the look of the heads vs the plug, looks more like the plug was put it after the switch was broken off.
BC GTA
Jun 2, 2009 06:45 PM
Apr 22, 2007 11:42 PM
Scottlb9
Aug 1, 2005 07:48 AM
Don_89Iroc
Jun 26, 2002 10:54 PM
