85 firebird trams am with 350 motor
Axle/Gears: 10 Bolt 2.73 Open
Re: 85 firebird trams am with 350 motor
Welcome aboard jjsears.
Can you define hot for us? 200 - 220 is not abnormal at an idle. Then there's the accuracy of the factory gauge to consider. Tell us a little more about what's happening.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If the new motor is in proper tune (and not too radical in nature) the factory radiator should be more than up to the task.
but, yes, define 'hot' for us.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
What Engine?
What induction system are you using?
What was the factory induction system?
What pump?
What thermostat?
What temps is it reaching?
When is it overheating (cruise, idle, acceleration, town)?
What temp is your fan turning on?
What pump?
What thermostat?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Is it carbed or TBI/TPI?
Did you remember to burp the motor when you put it all back together? Otherwise, what Midias asked is what we all need to know.
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
I'm in need of the same advice dont mean to hijack the thread but mine is almost identical and I c this is a week old. I have a 84 z ho just bought a remain stock long block all factory,all new sensors knock coolant new water pump and just bought a new rad and T stat .I been trying to break it in and run it 20min at 2k but it will only last 5 mins and get hot enough for the check engine light to come on .My gauge I dont think works it said 160 the fans did come on,I guess the come on around 225,thats to hot for me and a new engine. Like I said all stock,wanted it to b factory .What I'm I missing .
Car: 1984 Trans Am
With the radiator cap off, run the motor and watch the coolant flow. It should bubble up and out then the level will drop. This is burping the air out of the cooling system. 3 or four of those bubble outs should steady it. Refill and yiu should be good. The air bubbles escaping wont let it cool properly if they're trapped in the system.
DD9TransAmGTA
Exterior Parts for Sale
Aug 16, 2017 07:31 PM
johns84bird
Aftermarket Product Review
31
Feb 13, 2002 11:23 AM
and also are you sure your fan is strong enough and that the thermostat is opening?
