82 Trans Am air dam deflector replacement alternative
Old Nov 10, 2018 | 09:35 AM
xxyuroxx's Avatar
So i recently purchased an 82 trans am, but the front air dam deflector is totally gone (the one that's below the bumper area). Researching i found that the correct gm part number for this specific car year is 10017673. However, this part is long discontinued now. I saw conflicting reports that possibly part number 12395557 would fit, as it is the newer 3 piece version, and is not discontinued. So i went to my local dealer, and in his computer, he shows that 10017673 is the only correct part number for an 82, with no alternate part number. I had him look up 12395557 as well, but he confirmed this is not for an 82. I also checked AllData, but didn't seem to find any info there either.
So my question is, is there any alternative or aftermarket version for 10017673 that exists nowadays, or can be modified to fit properly? Or maybe even some DIY advice with material from home depot, lowes, etc? Anyone have any experience with this?
Thanks!
Old Nov 10, 2018 | 10:51 AM
nhgator's Avatar
Car: 1985 T/A
Re: 82 Trans Am air dam deflector replacement alternative
I made one from a strip of old conveyer belting from a gravel pit,you can kinda see it in the pic..
Well,I had a pic,this site won't accept it for some reason.
Old Nov 10, 2018 | 01:30 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If your not concerned about 'factory correct' and just need an air dam, you can just bolt a camaro one on...
https://www.ebay.com/p/85-92-Camaro-...3929/657554727
If the car still has the mechanical fan, the air dam isn't really needed
Old Nov 13, 2018 | 12:56 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I found mine in from Ricks Camaro. Also I think Classic Industries has them. Alternatively a junk yard probably has one or two that are still serviceable.
Old Nov 13, 2018 | 02:14 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Last time I hit the local Pick Your Part there was a very clean looking Firebird maybe 83 or 84. Didn't look at it too much but it may have one if that part spans several years.
Can maybe look if I go again soon if that would help any
Henry
Old Nov 13, 2018 | 03:02 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
you need to do some modification to make the newer style work. That's why it doesn;t match at the dealer since the dealer only has the CORRECT part for a certain year span.
Old Nov 14, 2018 | 08:58 AM
xxyuroxx's Avatar
Henry
Appreciate the offer, and of course i'd be willing to reinburse you for your time, shipping, and the part cost. No rush, so only if you happen to be going there for another reason. If you do go, please verify if it's a trans am model, or regular firebird. The trans am has a different part number than the regular firebirds, and wont fit. I am looking for the trans am version. For reference, check this old thread, and scroll down to see the pics of the air dam that person found. That's the part i'm looking for:
https://www.thirdgen.org/forums/cool...deflector.html
Old Nov 14, 2018 | 09:06 AM
xxyuroxx's Avatar
classic industries doesnt have it listed in their catalog for that year, and on their site they only have something similar, but labeled as "ground effect front spoiler" (Product # PT1500 or Product # F15200), so i dont think that's it. i did see an old thread mentioning an old part number that classic industries USED to have for that part (part# G4749), so maybe i'll give them a call and see if they can check that old part number in their system.
Old Nov 14, 2018 | 11:28 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Okay, so it's the one piece one that kitt me showed on that thread. I'll keep you and it in mind when I go next
Old Nov 14, 2018 | 05:21 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Here is another part number for the 1-piece air dam. 10017672. This is stamped on the NOS one I just bought awhile back. Also, FYI, this same air dam setup can be found on base Firebirds and Formulas all the way to at least 1990. Both my 89 Firebird and 90 Formula have the same center mount and one-piece 2 5/8" tall wrap around air dam as my 82 Trans Am. The center mount design may vary, but it will work.
Old Nov 14, 2018 | 05:31 PM
Car: 2 T-Tops
Engine: 327/305
Here is a pic of a center mount that mounts to the bottom of the radiator support:
This is the air dam that mounts to the center piece and to your side ground effects that go under the bumper and attach to the bottom and side of the fenders:
Old Nov 16, 2018 | 11:19 AM
xxyuroxx's Avatar
Thanks everybody for the feedback on this. I think I'll go to the dealer and risk getting the non-discontinued part # 12395557 (newer 3 piece version supposedly only for 83-90) just to try it. hawks motorsports and some GM parts sites claim it indeed does fit the 82 trans am, so we'll see. I'll report back whether it's successful or not or if any modding was necessary (hopefully with pics). If it doesn't fit at all, i'll just resell it on ebay and get most of my money back that way. Hopefully this future info will help others out too in the same situation!
I also called classic industries, they dont have it either. Gave them an old part number from an old catalog from back when they did have it, but they no longer carry it.
Old Nov 30, 2018 | 04:44 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
what do the 91-92 model Firebirds use? hoping for a diagram too?
Old Nov 30, 2018 | 05:17 PM
Drew's Avatar
Which one? The GFX version has the side pieces of the 3pc airdam bolted to a lip on the front fender gfx. The non-gfx cars (formulas) have a filler panel that extends down with a lip that the side pieces bolt to. Only the center is the same between GFX or no GFX.
I still need to find an NOS Left filler, and either NOS or Very Good center...
Old Dec 2, 2018 | 12:54 AM
zman1969's Avatar
Car: 90 Formula 350
Drew, what I'm looking for is non GFX is that whats pictured?
Old Dec 2, 2018 | 03:59 AM
Drew's Avatar
Yep. We don't serve their kind (gfx Firebirds) round here!
Actually, I got those side pieces on accident. My Pontiac parts guy ordered in the Formula style when I needed the gfx style for my gray Firebird. I went ahead and bought them as spares for my Formula.
Old Dec 2, 2018 | 03:20 PM
zman1969's Avatar
Car: 90 Formula 350
are any of the extensions available new or A/M or just gotta start turning over rocks looking for them? are the center pieces available?
Old Dec 2, 2018 | 06:39 PM
Drew's Avatar
All the 91-92 bird parts are discontinued. I have had the side pieces laying around since the mid 2000's, and the filler panel was something I happened across on Ebay. Every so often a piece will pop up here or there, but I'm sure I'm not the only one looking. I think I've got just enough OK used pieces to finish the Green car, and the NOS parts are my backup.
Old Dec 31, 2018 | 10:21 AM
xxyuroxx's Avatar
Just wanted to update, someone actually listed one on ebay, the original 1 piece style, for $75 so I bought that. It's off an 83, so it should fit. Theres still one left as of the time of this post, if anyone needs one also.
Old Apr 29, 2021 | 12:01 AM
michaellong's Avatar
Sorry to drag up an old thread but do you reckon they still have this?
pontiacsteve
Jun 13, 2019 01:11 PM
FloridaZeke
Exterior Parts Wanted
22
May 30, 2013 08:52 PM
seanof30306
Exterior Parts for Sale
Aug 4, 2010 11:27 AM
FloridaZeke
Nov 22, 2009 09:39 AM
