Cooling Fan control
Old Jan 3, 2019 | 01:09 PM
buckweber's Avatar
Car: 1989 RS Convertible
Engine: 305 TBI
Transmission: Automatic
Cooling Fan control
i read a post that stock fan controller turns on @ 220 degrees for pollution control. There was mention of after market switches set for 180 or 185 degrees. Where can I find manufacturer / model info?
thanks
Old Jan 3, 2019 | 01:24 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cooling Fan control
Post #20 the sw555 is a good choice not to your specs though
https://www.thirdgen.org/forums/cool...an-switch.html
Old Jan 3, 2019 | 01:27 PM
Engine: Lb9
Transmission: M20
Old Jan 3, 2019 | 01:28 PM
Engine: Lb9
Transmission: M20
Old Jan 3, 2019 | 01:53 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
This is what I used for my trans cooler
https://www.ebay.com/itm/4-PACK-180F...gQje:rk:1:pf:0
4x Pack of them for $30. Simply wire in a relay and go.
They seem reliable as long as you don't pour salty water on the plugs (don't ask how I know)
Old Jan 3, 2019 | 05:53 PM
buckweber's Avatar
Engine: 305 TBI
Awesome. Thank you
Old Jan 5, 2019 | 09:07 AM
buckweber's Avatar
Engine: 305 TBI
Ordered it up
Old Jan 22, 2019 | 07:19 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
When you get tired of messing with the switch, try a Dakota Digital PAC-2750 fan controller. I tried no less than half a dozen different brand fan switches on my wife's 1987 Camaro. None of them would turn the fans on / off at consistent temperatures. I had a PAC-2750 on my 1985 Camaro and finally put one on hers too. No more issues and it has worked perfectly ever since.
Old Jan 22, 2019 | 12:09 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I used a SW555 been good for 7+ years comes on right at 210 per my aftermarket temp gauge and 211 per my IR gun.
Old Feb 3, 2019 | 01:49 PM
buckweber's Avatar
Engine: 305 TBI
I instantly new fan control sensor. Drivers side under exhaust manifold. Single wire. Temp gauge stopped working? I thought temp gauge worked of 2 wire sensor on intake next to thermostat housing. I am not one for coincidences. Any ideas?
Old Feb 3, 2019 | 02:02 PM
Not really a coincidence... see my signature.
Temp gauge sending unit (not really a "sensor") is between the #1 & #3 spark plugs. Sounds like you disabled it by putting your other thing there.
Factory fan switch location is the same hole in the other head; between #6 & #8 spark plugs. I'd suggest putting the temp gauge sending unit back and hooking its wire (dk grn) back up; and putting your fan control thing over on the other side.
The 2-wire sensor (this one really IS a "sensor") is for the ECM. Not related to gauge function.
Old Feb 3, 2019 | 02:16 PM
buckweber's Avatar
Engine: 305 TBI
I meant I installed the new fan control sensor
Old Feb 3, 2019 | 02:18 PM
buckweber's Avatar
Engine: 305 TBI
Thank you. I will put it back the way I had it
SNET Telly
Aug 8, 2004 11:31 PM
chevypower
Mar 15, 2004 04:33 AM
89 Iroc Z
37
Dec 2, 2003 12:16 PM
aziroc
Jul 19, 2002 02:44 PM
