Classic auto air install
Old Mar 30, 2019 | 09:33 AM
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
I’m almost to the point of needing to charge the system.
Is there anything else,other then Freon,that’s not included that I would need.
Old Mar 30, 2019 | 11:01 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: Classic auto air install
yes, you must completely clean all residual R12 AND oil if you are doing a conversion. if you do not, you will not have optimum results and it may fail, possibly causing compressor to blow up.
Old Mar 30, 2019 | 11:06 AM
LiquidBlue's Avatar
Transmission: MD8
Did a lot of research on this a while back and concluded that 50% of the reason people complain that r134a is not good is due to improper use. here are some links. https://www.thirdgen.org/forums/tech...ml#post6243605
BizJetTech's Avatar
Be sure to add the correct amount of the proper oil
Old Mar 30, 2019 | 11:08 AM
ULTM8Z's Avatar
check to make sure the compressor has oil or not already. many already come pre-charged with oil.
Old Mar 30, 2019 | 11:29 AM
BigBlock73's Avatar
Engine: 5.7
Only thing not new is the evaporator which was removed and flushed with acetone multiple times.
Compressor comes pre-oiled.
Back to the original post.
Does that charging kit come with everything needed to do initial charge?
Old Mar 30, 2019 | 12:18 PM
Drew's Avatar
You don't have Harbor Freight out there? Not sure what Amazon charges for the kit, and I'm too lazy to go look, but you can get a set of gauges and a vacuum pump, that likely come from the same factory, at Harbor Freight.
Looks about right, you need a gauge/manifold set, vacuum pump, and a can tap. The T-style screw in can taps are OK, I've had mine for 20 some odd years and used it too many times to recall, but I really prefer the clamp on style that punches the side of the can - they leak less. Not to mention the clamp on side tapper don't care what the can is... It'll punch a hole in a can of R12, R134a, air duster, spray paint, WD40, it... Don't... Care...
Disclaimer: - Drew-it-Yourself Industries does not condone nor recommend charging your A/C system with spray paint or WD40. That was clearly a joke. Drew-it-Yourself Industries accepts no responsibility or liability for any consequence resulting from application of any and all information contained here-in.
Old Mar 30, 2019 | 12:24 PM
BigBlock73's Avatar
Engine: 5.7
The Harbor Freight set costs more and doesn't come with the tap for the can.
The Amazon kit is $129
I want to do this myself to pull vacuum,check for leak's and repair if needed.
I don't have a shop that is convenient for me.
Old Mar 30, 2019 | 12:26 PM
BizJetTech's Avatar
FYI - Just because the compressor comes pre-serviced with oil does not mean you are good to go.
The system requires a specific amount of oil (total system capacity) and when you replace an entire system the amount of oil
that comes in the new compressor may not be enough.
Old Mar 30, 2019 | 04:23 PM
BigBlock73's Avatar
Engine: 5.7
I’ll give them a call on Monday and ask about the oil required
Old Apr 14, 2019 | 05:18 AM
BigBlock73's Avatar
Engine: 5.7
Called them and was told compressor comes with all the oil needed.
Finished the install and went to hook up the vacuum pump but the quick connectors supplied with the Kozyvacu kit don't fit on the 134A adapters supplied with the Original Air kit.
Want to get the correct quick connect fittings but unsure which one I need.
Old Apr 14, 2019 | 08:22 AM
BigBlock73's Avatar
Engine: 5.7
Correction
The low side fits (blue)
The high side doesn't (red)
Old Apr 14, 2019 | 01:46 PM
BigBlock73's Avatar
Engine: 5.7
https://originalair.com/88-92-camaro...t-134a-stage-1
Old Apr 15, 2019 | 02:11 PM
BigBlock73's Avatar
Engine: 5.7
I sent Original Auto Air an email.
Will see what they have to say.
Old Apr 17, 2019 | 03:31 PM
BigBlock73's Avatar
Engine: 5.7
No response to email
I keep calling the tech support
Keeps saying everyone is busy and to leave a message.
I left a message,will see if they call back.
Old Apr 23, 2019 | 06:58 AM
BigBlock73's Avatar
Engine: 5.7
Talked to the tech support.
Guy named Curtis,worthless conversation.
Kept telling me that I was trying to hook the quick connect to the wrong port.That the port was on the back of the compressor.
Wouldn't listen when I told him that he was referring to a different system,I asked him to pull up the installation instructions from his site so I could correct him on the system in my car.He told me he knows what he's talking about and that I was wrong.
He liked telling me I was wrong,multiple times, and refused to listen to me.
I was shocked at the combative attitude he had.
I told him to have a nice day and hung up on him.
Worst tech. support I ever had.
So not knowing why the quick connect wouldn't fit,I ordered a new set of quick connects.
Same issue.
I figured out that the 134a adapter they sent was to big to fit into the connector so I filed it down.
Now it fits.
This is after I found,during the install, one of the hoses that they sent didn't have one end crimped at the factory.
I called the sales dept. and they apologized and said they would send a replacement only after I sent photo's.
They took 2 days to ship and sent it the cheapest,slowest way.Took a week to get.
Open the box to find the wrong hose,call back and I'm told "it's only one part number off"(with a nasty tone) and that they will send the correct one.
I told him I wasn't happy with how they handled and shipped the last replacement and to ship in out immediately and send it overnight.
I'm ready to charge the system and hoping to not have anymore issue's.
Old Apr 23, 2019 | 10:55 AM
BizJetTech's Avatar
Wow, not good to hear about Classic Air - all the difficulties you've encountered makes me think I dont want to use
their product - I hope it works out for you in the end
Old Apr 24, 2019 | 05:38 PM
Kerrys914's Avatar
This sucks... I am getting ready to buy the kit but this news is not good to hear.
I haven't been able to find any other options out there for conversions to my 89
Old Apr 24, 2019 | 06:59 PM
Drew's Avatar
Not sure why anyone needs an aftermarket conversion... If you can get the system to seal up, the stock R4 compressor based system works great with canned air duster. Some people even have reasonably good luck using 134A. Yeah, an aftermarket modern compressor is nice, but it doesn't fit that well and it sounds like it's a pita to deal with the vendors and kits.
Old Apr 24, 2019 | 07:36 PM
Kerrys914's Avatar
MY compressor is toast so I need to buy one anyway.
Just looking to get my AC back and upgrade while at it.
Old Apr 25, 2019 | 05:20 AM
BigBlock73's Avatar
Engine: 5.7
I think once I get the this all sorted it will be very good.
Fit is good.
Will take some pics soon.
Waiting for some time when it's at least 70* to charge system.
Old Apr 25, 2019 | 06:23 AM
BigBlock73's Avatar
Engine: 5.7
Old Jun 13, 2019 | 06:17 PM
BigBlock73's Avatar
Engine: 5.7
Charged and working very well.
After all the issues, I'm happy with the installed system.
Old Jul 16, 2019 | 08:45 AM
willyjoejr's Avatar
Car: 1985 T-Top RS
Transmission: currently a T-5
What year is your Camaro? Which kit did you buy?
Old Jul 16, 2019 | 09:24 AM
BigBlock73's Avatar
Engine: 5.7
1990
Old Jul 16, 2019 | 09:26 AM
Kerrys914's Avatar
I installed the stage 3 as my evaporator was ruined.
Works great in St. Louis heat and I did the install myself.
Paid $80 to have is charged by a pro with proper tools
Old Jul 16, 2019 | 01:18 PM
willyjoejr's Avatar
Car: 1985 T-Top RS
So my struggle is I have an 85 camaro. Guess in order to reorient the compressor I would have to change brackets and move accessories on the engine. Thanks for the info big blck.
Old Jul 16, 2019 | 01:28 PM
BigBlock73's Avatar
Engine: 5.7
Only finding 86 and up,don't know what changed between 85 and 86
http://thepartguy.com/ac-upgradesCAMARO.html
Hawgtied
Nov 27, 2020 11:51 PM
siuol
Jul 20, 2017 07:50 PM
thomas1976
May 16, 2011 05:49 AM
Ozz1967
Mar 27, 2011 07:49 AM
jamieriplilb
Feb 4, 2008 08:53 PM
