Fresh Antifreeze found after driving
Old Jul 15, 2019 | 08:06 PM
Marc Webber's Avatar
Car: !982 Trans Am
Transmission: 350 Turbo
Axle/Gears: 3.08
I just got through putting my car back together a couple of weeks ago. I just got back from a short drive a few mins ago. I decided to pop the hood and look over a couple things. When I popped the hood I noticed antifreeze on the passenger side of the engine bay. It wasn't much but it was on the battery and the ac hoses and little on the fan shroud. Couldn't find any leaks. I suspect a radiator cap. What do you guys think. All hoses are tight including the over flow. Any advice or answers would be welcome.
Thanks in advance
Old Jul 15, 2019 | 08:51 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
Re: Fresh Antifreeze found after driving
As in you did a complete engine rebuild? just had the engine out and reinstalled? Or something else?
If the cap is old, replace it regardless as it is just good maintenance to do so and would eliminate the issue.
I'd pull the overflow line off and check it for blockage and pinholes. If you can remove it without taking the clamp off the hose is too worn at that spot likely. I noted mine looked mushing at the rad connection after I removed it.
But the best bet is to drive it again and pop the hood and check where it is coming from. It could be a rad hose, a heater hose, pin hole in rad and fan is spraying it etc.
Look inside the rad shroud and bottom side of rad too.
G/L
Old Jul 15, 2019 | 09:09 PM
Car: !982 Trans Am
Axle/Gears: 3.08
No not a rebuild but had the engine out. I drove it 60 miles the other day and no problems. The cap and radiator are under 3yrs old and the car has only seen 5000 miles since the radiator was new. I looked at the over flow hose and it appears in good shape. I did add some royal purple purple ice to the cooling system about a week and a half ago.
Old Jul 15, 2019 | 11:03 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Hairline crack in overflow bottle? Is the bottle cap still venting through?
Tstat housing leak?
Maybe just a fluke, but I'd keep looking for the answer.
Old Jul 16, 2019 | 04:43 AM
Car: !982 Trans Am
Axle/Gears: 3.08
Going to replace cap first. I just removed the cap and antifreeze was up around the top of the cap. If they're working correctly you usually won't see that.
Old Jul 16, 2019 | 09:02 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Any chance it's from the A/C system instead of being coolant?
Old Jul 16, 2019 | 08:36 PM
Car: !982 Trans Am
Axle/Gears: 3.08
Nope its for sure coolant. I found the crack in the overflow bottle.
Old Jul 17, 2019 | 12:03 AM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Glad you found it.
Old Jul 17, 2019 | 05:25 PM
Car: !982 Trans Am
Axle/Gears: 3.08
me to
Calixbwsx
Sep 7, 2013 02:08 AM
600_dollars
Jan 3, 2003 11:38 PM
zupmanZ28
Jun 17, 2001 08:15 AM
