heater core: which hole is the inlet and outlet?
Old Sep 12, 2019 | 08:02 AM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Hi all,
I have replaced my heater core, and want to double check that I will be connecting my hoses right. My 86 iroc-z has one hose coming out of the water pump and the other from the manifold. I belie
ve the one from the manifold goes to the right side hole, if I am looking at it from the front of the car . Is that correct? I marked with a blue arrow where I think it goes in the picture below.
Thanks in advanced!
Old Sep 12, 2019 | 11:33 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: heater core: which hole is the inlet and outlet?
The large connector goes to the water pump.
Small one to the intake manifold.
Old Sep 12, 2019 | 12:09 PM
podiatra's Avatar
Engine: 350 swap
Thank you!
optima23
May 26, 2014 06:15 PM
StrokedZ28
Aug 5, 2006 11:18 PM
mist1006
Jan 23, 2004 04:46 PM
305tpiz28
Dec 7, 2003 06:13 PM
jeremy178
Oct 5, 2003 12:03 AM
