I’m looking to use this ‘92 Z28 engine oil cooler on my ‘87 IROC. A couple of questions:
1. Is there supposed to be an O-ring or gasket between the cooler housing and block? I removed it from the engine, and there was nothing. It had also been leaking.
2. What do the two coolant hoses hook up to? A junction Y?
That's the 91.5-92 style oil heater/cooler, or more accurately a heat exchanger. It works both ways, whichever is cooler (oil or water) will "cool" the other, the warmer of the too will exchange it's heat to the other. Except in limited 'cloning' endeavors, I probably wouldn't add it to a car that didn't have it.
I'm not intimately familiar with that setup. I'd have to look it up on one of the GM dealership websites and look at the diagrams. Look on Google for GMpartsgiant and look for the oil cooler diagram on their system. I'd expect there's a seal of some kind, probably an O-ring or a composite aluminum/rubber seal like you'll see on V6 fuel rails, or A/C lines, etc.
I had it. I removed it as a had a pinhole in the metal lines and didnt want to fix something that will eventually break from somewhere else. I then discovered that the engine run cooler without it.
Conclusion. It is meant to heat the oil faster in very cold weather similar to passing coolant across the throttle body to unfreeze the butterflies.
If you really need to cool engine oil, get a proper air to oil cooler.
