Radiator fan doesn’t turn on by itself
Old Jun 9, 2020 | 09:56 PM
blaze2fury's Avatar
I have an 84z and the radiator fan doesn’t turn on unless I have the A/C on. I’ve let it sit and idle through a nail biting temp of around 240ish and got nervous and flipped on the A/C. Have done this about two times because I didn’t wanna keep letting it get that hot. Any ideas guys? Would love to not always worry about turning my A/C on (even though it doesn’t work) to have my fan turn on. Thank you.
Old Jun 9, 2020 | 11:10 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Radiator fan doesn’t turn on by itself
there is a fan switch in the passenger side head.
Old Jun 9, 2020 | 11:13 PM
Car: 1984 T/A
Engine: LQ4
from alldata
Old Jun 10, 2020 | 03:13 PM
blaze2fury's Avatar
Is it easier to get too from under the car or above?
Old Jun 10, 2020 | 06:09 PM
Usually easier from above. Just like spark plugs (it's in between 2 of them).
Unplug its wire; with the key on, ground the center pin of the pigtail, with a small piece of wire or something; the fan should turn on. If it does, the problem is the switch or the pigtail. If it doesn't it's probably the wiring. Some of the wiring, and the motor & relay, would have to be working properly for it to work with the AC, so those parts can be ruled out.
Old Jun 10, 2020 | 07:04 PM
blaze2fury's Avatar
Switch was unplugged so I plugged it back in and it turns on and off by itself now. Does it at a hair above 220 but goes off and on. Alittle high for my liking but I might just leave it cause why fix something that works.
Old Jun 10, 2020 | 08:11 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
And also, the car ,as most have, has made it 36 years running at stock temps just fine.The stock head located fan switch for electric fans (v6, v8) turns on at 238°F for all years (excluding the 89 TTA iirc)
Old Jun 10, 2020 | 08:18 PM
See my signature.
mxxdude
Jan 19, 2011 04:42 PM
Artic White
Jul 31, 2008 02:06 PM
Frank_Blotto
Apr 12, 2004 01:50 PM
brharris27370
Sep 3, 2002 08:27 AM
LarryDodd
Jun 27, 2001 02:01 PM
