Corolla Dual Fan Upgrade
Old Nov 9, 2020 | 11:34 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I decided my single fan could use an update after some forum searching I found that the 92-02 Corolla dual fan (TO3115106) was a great fit. I got one on ebay for about $80 and also picked up some factory pigtails for the fan so I could use the connectors it came with and make my own harness
To make the fan fit I trimmed down the factory top fan mount then fabbed up some upper and lower mounts.
Parts I used
Fan (PN TO3115106)
Pigtails for fans
http://www.autolumination.com/wiring...-connector.htm
Box, flat and angle steel
Sealed relays
Amazon Amazon
Fan Switch 212 on 205 off (PNs SW555, TS136, 35946, 1S4394, 3053190)
Connectors
Amazon Amazon
The only snag I ran into was the thermal switch did not like activating two relays. I am not sure if it was an inductive kick back issue I could have solved with a diode but I decided to add a helper relay so the switch would be back to its normal stock mode
The bottom mount was angle iron with some 1" box steel I added some 5/16 studs
Relay configuration
Top and bottom mount test fit
Weld nuts for top mount
Final install
Old Nov 9, 2020 | 01:40 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Corolla Dual Fan Upgrade
Originally Posted by midias
Your relay configuration is wrong 58 and 86 are the control contacts for the relay. Wiring like that would do nothing but, probably, just burn up the relay
Old Nov 9, 2020 | 01:52 PM
midias's Avatar
Your right I drew it 90 degrees off fixed
Old Nov 28, 2020 | 06:04 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Nicely done; that looks like something I would have done.
I installed a Toyota fan setup on a buddy's '79 Cutlass a few years ago, but he used one of those adjustable controllers (which I do not like).
This is the Chevy Malibu fan swap I did a few years ago: https://www.thirdgen.org/forums/cool...tallation.html
Old Nov 28, 2020 | 07:47 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
If I may ask, why didn't you go with LS fans? They are a direct plug & play. Plus, the shroud for the LS fans doesn't leave a gap at the top of the radiator.
Old Nov 29, 2020 | 12:57 PM
Engine: TBI 305
Because I didn't have an LS fans available.
Old Nov 30, 2020 | 10:57 AM
midias's Avatar
I did not consider LS fans I knew that corolla fans could be very effective and were shrouded better than the stock one so I went for it. I really liked the mod in the summer it was super effective.
Old Nov 30, 2020 | 11:39 AM
Huh? Midas is the one who did the mod. Why are you answering for him?
Old Dec 1, 2020 | 03:01 PM
Engine: TBI 305
Because you posted directly under my post, so I thought you were asking me, in reference to my linked Malibu fan installation.
To avoid further confusion in the future, quote the person you are talking to.
Old Dec 1, 2020 | 03:34 PM
Didn't even see your link.
Old Mar 23, 2023 | 11:11 AM
midias's Avatar
Wanted to give an update. I have been running this system with my sniper EFI one output per relay and still cooling the car great. Just transferred it to my new build but I rebuilt the top mount to make it look better.
Old Mar 23, 2023 | 03:22 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
I like that top mount much better! Its all in the details. Great job.
irishhockey34
Oct 11, 2020 03:12 PM
Vinscully50
Sep 14, 2020 07:09 PM
okay
May 23, 2020 03:51 PM
85_SS
Jun 18, 2013 10:24 AM
