No heat
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: No heat
after coolant level is checked, warmup the engine.
feel the heater hoses before and after the control valve to determine where the coolant is stopped.
if warm to heater core might be a mode door issue.
Car: 1991 base firebird
Engine: tbi 305
Re: No heat
my car was doing this. turned out that at some point the heater core started leaking so they moved the hoses around any bypassed the heater core. so no heat until i replaced it.
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Re: No heat
Your thermostat may be stuck open. What does your engine temperature read? My 89 convertible has a stuck open thermostat right now. I drove it 30 miles to put it in storage for the winter a couple months ago and my engine temp barely registered anything on the gauge and I had ZERO heat. I thought I was gonna freeze, lol.
