replacing duel cooling fan motor.. how to
Old Jun 7, 2022 | 08:50 AM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
Hello,
I have a stock 1987 5.7 Iroc. The driver's side fan is turning vey slow and I want to replace the motor, keeping it factory. What is the method? Can I RR fromt he top or do I have to put the car on a lift?
Any insight would be great.
Old Jun 7, 2022 | 09:37 AM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: replacing duel cooling fan motor.. how to
you can unbolt the fan assembly from up top. Each fan should be 3 bolts. Once you have the fan out you can remove the fan blade. On the backside you will see bolts for the fan motor assembly. Pretty straight forward.
Old Jun 7, 2022 | 07:18 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Just remember that the nut that holds the fan to the motor is reverse thread
Old Jun 7, 2022 | 08:52 PM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
Thanks for the help! Completed this afternoon. Pretty easy.
xxbrew1690xx
Apr 1, 2012 06:10 AM
fltche1
Jul 18, 2010 12:26 PM
Bobby_80s
Apr 30, 2010 09:55 PM
IROCU2
Aug 25, 2007 02:58 PM
alohaboyz
Jul 1, 2003 08:07 PM
