Cooling fan.
Old Apr 26, 2023 | 10:04 AM
Blaise's Avatar
Cooling fan.
I bought a 91 swapped to 350 formula along with the engine swap it has an aftermarket radiator and coolant fan setup, theres a thick black wire not connected to anything coming from the fan that when plugged directly into the positive side of the battery turns on the cooling fan after a little bit of searching it looks like I still have all my fan relays and such but I cant figure out where that black wire is supposed to be wired to any thoughts or help would be greatly appreciated.
Old Apr 26, 2023 | 12:16 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: Cooling fan.
here are a few ideas to get you started
https://www.thirdgen.org/forums/v6/4...ml#post3801073
https://www.thirdgen.org/forums/cool...ml#post6313611
Old Apr 26, 2023 | 01:00 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Cooling fan.
Pics would help!
Bitchin'Camaro
Sep 14, 2012 04:55 PM
IROCJoyce
Aug 7, 2009 08:41 PM
92FormulaBird
Apr 23, 2008 08:50 AM
gogo90camaro
Sep 15, 2004 06:12 AM
88355
Jun 9, 2002 09:03 PM
