Check the obvious stuff first
Old Jul 29, 2023 | 09:29 AM
Grant2k's Avatar
Car: 1992 RS
Engine: Iron 5.7 LS
Axle/Gears: 4th gen rear, 3:42s, Torsen
This is a stupid story that showed me again to look first at the things that seem obvious.
I put LS1 fans in my car and bought factory style pigtail plugs on ebay for the fan motor connections. I made my own wiring harness with new relays and wrapped it all nice, put it in, idled the car until the fans came on and was happy it all worked great. When I tried to drive it the temp immediately went up, and the faster I drove the more the temp rose. If I pulled over and idled the car the fans would immediately bring the temp back down. I was confounded. I bled the radiator and was wondering if my water pump was bad or something.
Standing in front of the running car I noticed a lot of air on my ankles. I held a piece of paper in front of the car and it blew outwards. I put it near the fans under the hood and they sucked it right in. I had wired the fans according to the wire color on the cheap pigtails I had bought which turned out to be backwards from what the fan wanted. Being DC motors, they were spinning backwards. Swapped around some wiring and it works great. So the lesson is check what might seem overly obvious first before you start pulling your hair out like I did.
Old Jul 31, 2023 | 02:21 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Check the obvious stuff first
We all have done something like this in our past and possibly will do it again in the future.
MARTIAN91
Sep 26, 2022 10:33 AM
bungo78
Jul 17, 2010 01:01 PM
gscz28
Feb 18, 2009 07:19 AM
firebirdjones
Jul 26, 2005 01:00 PM
