Custom Rad Hoses: Who Does What?
Old Sep 22, 2023 | 09:19 AM
skinny z's Avatar
I have a thread regarding the lower rad hose on my V8 Camaro.
https://www.thirdgen.org/forums/tech-general-engine/786521-lower-rad-hose-1-a.html
Because of the aftermarket rad, I need 1-3/4" on both ends of the lower hose.
Seeing as many of the engines swaps I've checked out have spliced hoses, I'm asking if there's a go to supplier for the beaded nipples used between lengths of straight and or molded hose ends?
Anyone?
Old Sep 25, 2023 | 08:36 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: Custom Rad Hoses: Who Does What?
I've used these before....I think this may be what you are looking for?
https://www.ictbillet.com/1-1-2-to-1...g-adapter.html
Old Sep 25, 2023 | 09:03 AM
skinny z's Avatar
I wasn't thinking about an adaptor so much as a hose splice "kit" of sorts.
That said, that piece you posted a link to would at the very least clean up the look of the splice I now. The hose pictured above is actually two OEM lower hoses for a V8 F-body. It works well enough but it's an awkward looking thing. That ICT Billet piece would clean it up considerably with the splice at the rad rather than a third of the way along.
Thanks. If it can find it locally I just may go for it.
EDIT. Shipped from ITC to up here in Alberta works out to $45 CDN. Very much worth considering.
Old Sep 25, 2023 | 12:55 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Amazon.com: ICT Billet 1-3/4" to 1-3/4" Inch Hose Barb Splice Coupler Repair Mend Fitting Adapter Connector Radiator Coolant Intercooler Heat Exchanger Fluid Designed & Manufactured in USA Bare Aluminum AN627-28A : Automotive Amazon.com: ICT Billet 1-3/4" to 1-3/4" Inch Hose Barb Splice Coupler Repair Mend Fitting Adapter Connector Radiator Coolant Intercooler Heat Exchanger Fluid Designed & Manufactured in USA Bare Aluminum AN627-28A : Automotive
Amazon has a nice one for a nice price, and it has a lot of good reviews
Old Sep 25, 2023 | 01:49 PM
skinny z's Avatar
I saw that one but I'd be needing a 1-1/2" to 1-3/4" adaptor. That way I could use an OEM hose with a short length of 1-3/4" straight hose at the rad and adapt to the 1-1/2" hose end.
Old Sep 26, 2023 | 06:10 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
There was a guy on crownvic.net that wanted to eliminate his oil cooler , so he got a piece of 1.5" aluminum, 18" long, and he rolled a bead onto the ends with some special pliers he had.
I don't see why you couldn't do something similar.
Hell, back in the '90s, my brother swapped a V8 into his formerly 6-cylinder F150, and the water inlet/ outlet was swapped.
So he cut some galvanized pipe to size, threaded it for some elbows, and used some short pieces of the old hose to connect the pipe to the radiator and engine.
You really had to see it to believe it, and it really worked. He drove it that way for years.
Old Sep 26, 2023 | 06:19 PM
skinny z's Avatar
I had access to a bead roller at one time and we often made custom pipes for this very purpose. That was back in the infancy of LS swaps and there was nothing out there. Come to think of it, the splice in the hose pictured is just that. A length of aluminum tube that's been bead rolled .Those days are over though as I left that shop ten years ago.
For my heap, I want something tight. I thought I had a line on a one piece molded hose but it was too short. That short adaptor (ITC Billet) would sort of be out of sight right at the rad outlet so that's the best I'd come across so far.
I had a similar deal with the top hose (1-1/2" x 1-1/2' hose ends rather than 1-1/2" x 1-1/4") but a Buick 455 from the late 60's had an exact fit. The same couldn't be said for the lower hose though.
Old Sep 27, 2023 | 01:02 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Amazon.com: ICT Billet 1-1/2" to 1-3/4" Inch Hose Barb Splice Coupler Repair Reducer Fitting Adapter Connector Radiator Coolant Intercooler Heat Exchanger Fluid Manufactured in the USA Aluminum AN627-28-24A : Automotive Amazon.com: ICT Billet 1-1/2" to 1-3/4" Inch Hose Barb Splice Coupler Repair Reducer Fitting Adapter Connector Radiator Coolant Intercooler Heat Exchanger Fluid Manufactured in the USA Aluminum AN627-28-24A : Automotive
There you go
Old Sep 27, 2023 | 01:22 PM
skinny z's Avatar
Yep. That's the one linked to in post #2.
Either ITC as per the link or Amazon Canada.
Old Sep 27, 2023 | 04:46 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Hmm, im not sure what you're looking for then? Do you have a pic?
Old Sep 27, 2023 | 04:55 PM
skinny z's Avatar
Ideally, I'd like a one piece molded hose like I found for the top.
But if a splice is needed, the ITC part you posted will do the job. ( by the way, I wasn't knocking your suggestion, it's just that it was the table already). Not a lot different than what I have now though ( hose pictured above).
The splice is what I'm trying to eliminate.
Old Sep 27, 2023 | 05:11 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Ohh i see i see
no worries!
I'm not sure but I am thinking maybe some heavier duty trucks like the HD Chevy / Fords etc.. might have what you're looking for. .
You could try go to a parts store and tell them what you're looking for, and they might let you walk in back to look at the hoses they have on hand...
I did that when looking for my TB coolant bypass. They let me look at the hoses they had on hand and I got to see / measure and choose one that seemed to match my needs the most.
Old Sep 29, 2023 | 11:58 PM
Engine: TBI 305
This.
1) Go to parts store, and buy a 1.5" aluminum heat-riser tube.
2) Stretch/ bend it to fit the area that you need
3) take it to the back room of the parts store, and find the hose that matches best. I've done this a few times.
Old Sep 30, 2023 | 09:08 AM
skinny z's Avatar
Originally Posted by dixiebandit69
This.
I've done that more than once. Even a metal coat hanger mock-up can get you close sometimes. But I went one better this time and took the hose pictured in the 1st post (and below):
Still no luck.
Seeing as the top hose is from a 60's muscle car , it's not likely these are going to be hanging around. I don't even recall how I came across a proper fitting top hose it's been so long.
The suggestion of a HD truck application (also 60's era) isn't going to be stock item either.
The hose above does the job. It's just ratty looking.
Old Jun 23, 2024 | 11:56 AM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
From the look of the picture, it's routed properly, it looks like the aftermarket exhaust is closer than factory was. The existing clamp on the lower frame rail may be your best bet, just wrap the cable with something heat resistant so that clamp grabs it tightly rather than allowing it to travel back and forth.
skinny z
Sep 22, 2023 12:19 PM
skinny z
Jul 11, 2011 12:41 PM
gtpro700
Aug 15, 2008 08:07 AM
Camaro0605
Sep 12, 2007 04:31 PM
