Radiator Recommendation Wanted
Car: 92 Formula
Transmission: BW 5 Speed
I have an 88 Trans Am with a 383 that needs a HD Radiator......ordered one online but need to modify the lower support area on the car to make it fit....are there any HD direct fit rads that are a direct drop in with no sheetmetal mods necessary?....Thanks
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Radiator Recommendation Wanted
There is a difference between "direct fit" and exact fit.
Direct fit can still require some sort of modification. I installed a Griffin exact fit radiator in my '83...
Car: 1984 T/A
Engine: LQ4
Be cool, Frostbite, champion, quite a few to choose from. I currently have a be cool in my car.
Transmission: Pro-built 700R4
DeWitts
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I'm not sure if Dewitts is worth the money....unless you have the money and mindset for "Only the best!". If you want high quality bling....you can't go wrong with DeWitts. If you're looking for high value (high cooling capacity for low[er] $$) then I think something like a Champion is worth a look.
This coming from someone who bought and has a DeWitts, and it's good...it's a nice piece. If I were doing it again, however, I'd probably buy something less expensive, b/c the benefits of the DeWitts haven't really justified the price, IMO.
Champion does not make an "exact fit" radiator for these cars, and most of the others mentioned do not either. All can be made to work, but not without some kind of additional work.
I bought the Griffin because I wanted an exact fit but better than stock. It was over $700. I'm not wealthy, but cooling is important...
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
BeCool Rad is a direct fit, Running one with Volvo 2 speed fan. Cools down in seconds.
Engine: LT1, L400
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
Anyone have any experience on Frostbite (Holley) radiators? I see they are on sale but I am kind of weighing the quality vs price. I see some like Dewitts are quite pricey but it may go back to, "you get what you pay for." I will say I am replacing my L98 with a build 355 so I figure it would be a good time for a new radiator and not looking for "customizing" per se. Leaning towards Be Cool or Griffin
kitt23
Feb 16, 2012 04:24 PM
white85transam
Jan 9, 2007 06:08 PM
