Anyone with a Summit Racing Radiator?
Old Aug 28, 2004 | 04:33 PM
Camaro_nut's Avatar
Just wanted to know who is running the 31x19 Summit
Racing brand Radiator. I had installed one in my car. It
it not a direct fit, however. It requires some hammer
banging on the sides of the body. Can not use the stock
rubber mounts, upper or lower. Radiator support also
needs some modifying. After that, the thing fits in well.
But the side tanks do touch the body of the car. It does
not move however. I shake the radiator and the whole
car shakes with it. So, since it fits very snug, does it matter
if I don't have any space between the sides? I have space
between the condensor and radiator, as those rubber spacers
are still there.
Old Sep 3, 2004 | 04:31 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
The Be-Cool IS a direct fit. Bought it 'cause I didn't want to f*ck with it, and wanted to fix my cooling problem. And it worked.
Old Sep 3, 2004 | 09:29 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
Well, there are two Be cool Radiators. The 31x19 and the direct fit. I purchased the direct fit as well. It's worth the extra money to not have to worry about it like barry85iroc said.
Hammering on a radiator may not be conducive to proper cooling either lol
Old Sep 3, 2004 | 10:23 PM
Camaro_nut's Avatar
Well, both of you guys are not understanding me!
I had to hammer on the sides of the BODY of the vehicle.
Not the radiator. The radiator is aluminum. So, hammering
on it will make holes very easiely! PLEASE READ more carefully
next time. lol
And again, I am are NOT talking about the Be Cool direct
fit ones either! I am talking about the SUMMIT RACING
RADIATOR only. PLEASE ONLY POST IF YOU HAVE USED
the SUMMIT RACING RADIATOR ,thanks.
And I don't think that it is worth $550 for a direct fit one
either. Mine is only $185 and only needed to modify the
radiator support and modify the sides of the body of the
vehicle to make it fit. It actually looks like it was meant to be
there. Nothing looks hacked up either.
SO far NO ONE has answered any of my questions.
Old Sep 3, 2004 | 10:59 PM
Engine: 355
The reason it was brought up is the Summit racing one I believe is the becool one. You also mentioned there being spaces, no way of mounting just using body pressure to hold it in, so by saying now that you cant tell is contradicting yourself. Now the direct fit one you wont be able to tell.
Old Sep 6, 2004 | 10:03 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Old Sep 7, 2004 | 01:33 AM
Engine: 355
IE Direct fit is Direct fit, the other one has to be HAMMERED in lol He said he had to hammer it in and it sticks out (which the 31x19's do) Yet in another post he said you cant tell. Don't know aobut you but I can tell when someone has tried to take and put a square peg in a round hole with a hammer
Old Sep 7, 2004 | 12:48 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
I was under the impression that the Summit radiators are made by Griffin. Anyone know for sure?
Old Sep 7, 2004 | 12:56 PM
Tunedporttuner's Avatar
Car: !986 T/A
Engine: 350 Tuned Port,I know I did it
Not Sure about that but I doubt it.Otherwise they wouldn't sell Griffin radiators seperately in the catalog.The be cool radiators are kinda pricey,and the first question for you guys should be why are you havin to put in aluminum radiators anyway.I realize that mods will pump up the power and there by pump up the heat the engine produces BUT,with simple things like better fans and bypassing the fan relay switch you can keep yer car at 170 with the stock radiator,as long as the rest of the system is right.Unless your radiator was trashed or clogged and had to be replaced,in which case I understand the upgrade.
Old Sep 7, 2004 | 01:15 PM
Engine: 355
If fans and thermostats could keep these cars cool in traffic, than any 350 with dual fans would do it. Ask anyone on here with a 383, 406, 355, heck I put a brand new stock radiator in with my old 305 and it wouldn't stay cool. If fans and a thermostat could do it, companies like Stewart with have no reason to be in business.
Old Sep 7, 2004 | 07:26 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
On my thirdgen I run a 160 'stat and fan switch, dual electric fans, meziere electric water pump, and Modine stock replacement radiator. It always runs cool.
I'm considering an aftermarket aluminum radiator for my other project car (g-body) because it is the same price as the stock replacement radiator, and I have to buy one or the other.
Old Sep 7, 2004 | 08:35 PM
Camaro_nut's Avatar
Nope. Another company makes them. It's on the side
of my radiator, just don't know the name off the top of
my head.
Old Sep 7, 2004 | 08:44 PM
Camaro_nut's Avatar
A lot of false info and misunderstandings here!
Can a mod PLEASE delete this thread???? Thanks!
Bubbajones_ya
Jul 6, 2024 08:32 PM
Bohemian
Aug 15, 2017 05:11 PM
69GTOby
Apr 18, 2016 02:34 PM
sreZ28
Oct 22, 2015 08:21 AM
randy210
Oct 15, 2015 03:43 PM
