Cheap dual core radiator $87
Old Jun 26, 2024 | 10:36 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
My spectra 951 radiator developed a leak so I ordered a new OSC 951 radiator for $87 from Rock Auto and to my surprise it was a 1/4" thicker and two core. No issues getting it in and seems to be cooling great. Thought I would share
Old Jun 26, 2024 | 12:07 PM
czarjl's Avatar
Car: '82 Camaro Berlinetta
Engine: 305 Carb
Transmission: TH200
Re: Cheap dual core radiator $87
Interesting.... I just ordered the GPD 951C as it is called out as "2 Row Core"
When it comes in next week I will have to measure it.
Old Jun 26, 2024 | 12:25 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Went with the CU750. So far so good.
Old Jul 1, 2024 | 09:25 AM
midias's Avatar
My spectra radiator cooled fine but it started to leak. Went OSC a friend said his worked well and the extra thickness and row were a nice surprise
Old Aug 17, 2024 | 05:03 PM
Extrafitkid's Avatar
Car: 1986 TRANS AM
Engine: LB9
Old Aug 17, 2024 | 05:45 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
It says 2 row "equivalent". That's not the same as actually having 2 rows, but if it's cooling well, that's all that really matters...
Old Aug 17, 2024 | 06:15 PM
midias's Avatar
Originally Posted by T.L.
It says 2 row "equivalent". That's notthe same as actually having 2 rows, but if it's cooling well, that's all that really matters...
I know it says that but when I looked inside it was an actual 2 row
Old Aug 17, 2024 | 10:36 PM
T.L.'s Avatar
I got a new radiator for my Toyota 4Runner from Rock Auto last year and am quite pleased with it...
Old Sep 16, 2024 | 01:11 PM
Catbox's Avatar
Car: 1992 RS Camaro
Engine: 305 TBI
Just ordered the OSC 951 for my daughters car.
Old Sep 16, 2024 | 01:18 PM
midias's Avatar
Snap a pic of the inside when you get it
Old Sep 16, 2024 | 02:06 PM
Catbox's Avatar
Car: 1992 RS Camaro
Engine: 305 TBI
I will do that when it comes in later this week.
Old Sep 18, 2024 | 06:23 PM
Catbox's Avatar
Car: 1992 RS Camaro
Engine: 305 TBI
Man.
Rock Auto had this one fast tracked to us.
Ordered on Monday and have it in hand Wednesday.
It looks like two 5/8" flat tubes side by side in there.
I can snag my finger nail on the center section of the tubes.
If you squint and turn your monitor too 43 degrees you can imagine that you are seeing a seem that I describe above...
I spy the trans cooler section in there.
Hopefully this will help keep the temperatures in check.
After the system is cleaned with the proper coolant system flush.
Old Sep 20, 2024 | 02:26 PM
midias's Avatar
Awesome thanks for taking a pic. $87 for a two core is a great deal
snake70
Jul 1, 2024 08:59 AM
FAST RS
Jul 5, 2005 02:38 PM
92camarors5spd
Apr 2, 2005 04:36 AM
Z's r Best
Jul 25, 2004 09:32 PM
