Cooling fan
Old Jan 23, 2025 | 08:05 AM
C3sar16's Avatar
Cooling fan
Hello everyone I have a 92 Chevy Camaro 305 tbi with the single fan. And the fan is not coming on. I do not have the sensor or the passenger side head or the wire that goes there, ive tested the fan with running power to it and it works also I’ve grounded the wire going to the relay which is the ground wire and the fan will kick on. Any help would be appreciated
Old Jan 23, 2025 | 08:39 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Cooling fan
You don't have the fan switch in the head? If not, your fan never receives a ground signal to turn on.
Old Jan 23, 2025 | 08:55 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cooling fan
Install a wells sw555
Old Jan 23, 2025 | 09:31 AM
C3sar16's Avatar
Re: Cooling fan
Could it be that the connector got hooked up to the knock sensor ?
Old Jan 23, 2025 | 11:45 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: Cooling fan
Find the connector and plug it back in. Is there a sensor in the head without anything connected to it?
Old Jan 23, 2025 | 01:52 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Cooling fan
The knock sensor plug and the and the fan switch plug are very similar....... The plug for the fan switch to the relay should have a GREEN/White wire.
Here is the schematic for your electric fan:
You'll need to install a head-mounted sensor and then connect the proper circuit from the switch to the relay. If you still have a problem after the switch and plug are in place,... then start to try to diagnose further.
Old Jan 24, 2025 | 04:42 AM
C3sar16's Avatar
Re: Cooling fan
Thanks y’all for the help, I think I’ve found my problem, I need a new harness i bought the car for $500 it needs a lot of work was not running when I bought it. Finally got it running a couple of week ago and the engine harness has definitely been messed with, a lot of butt connectors.what’s not to say that wire got cut off. I’ll probably buy the sensor and the pig tail for and just tap it into the fans relay ground for the time being while I find a harness.
Old Jan 24, 2025 | 08:48 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Cooling fan
Yep, sounds your car has been "modded" by a previous owner. Good luck with that.
Old Jan 29, 2025 | 12:36 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Cooling fan
If you stock harness is fubared by a pervious owner you can always make your own fan harness. Here is an example.
affliction1
Aug 2, 2011 01:37 PM
sorch60
May 23, 2005 06:49 PM
88355
Jun 9, 2002 09:03 PM
LottaBallsCamaro
Apr 26, 2001 07:54 PM
