Which radiator for an '85 TA Heavy-Duty system?
Car: 1985 Pontiac Trans Am WS6
Engine: LG4 305/5.0L V8
Transmission: 700-R4
Axle/Gears: 3.08
My '85 Trans Am WS6 is in need of a new radiator; the original has sprung a bad leak. In order to keep the car looking as close to original as I can, which heavy-duty radiator would the Third Gen faithful recommended? Thank you in advance.
Car: 1984 T/A
Engine: LQ4
Re: Which radiator for an '85 TA Heavy-Duty system?
a stock replacement radiator works just fine. you should try to flush out the block when you replace it as well.
Axle/Gears: 3.08
Hey, Punkmaster98, yeah, doing the engine block flush is a good habit to get into. So the AC Delco radiator is going to set a guy back 5-bills, and I just have a hard time shelling out that much for a part I use to buy at the salvage yard for $20. O'Reilly's has a stock replacement for $150 that looks pretty good. I might go that route. Thanks for the reply! 247spin
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
A few members here seem to be happy with this OSC 951 radiator. @midias @Catbox
This radiator is 26.25" x 17.25" and has a 1.25" thick core and is marketed as a 2 row equivalent. I checked the normal parts stores Advance Auto Parts, Auto Zone, NAPA, and O'Reilly Auto Parts and the radiator they sell is a 26.25" x 17.25" x 1.00" single row.
Cheap dual core radiator - Third Generation F-Body Message Boards
OSC Automotive Products 951 OSC Automotive Radiators | Summit Racing
OSC Automotive Products 951 OSC Automotive Radiators | Rock Auto
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
The OSC is the only 1.25 two core I have found the rest seem to be 1"
So far so good cooling my car well and has the same construction as my factor one did
Axle/Gears: 3.08
I measured the old GM radiator and it's the exact same size as the OSC 951, which is great. Because my car has AC, installing a radiator with a 1.00" single row would just be asking for trouble. Thanks so much for this information, Airwolfe, I really appreciate it!
Axle/Gears: 3.08
Good to know, midias, thank you! I believe I'll be going with the OSC 951.
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
I recently got a champion 2 row for $250, it's all aluminum so no worries about the plastic tanks cracking. I haven't installed it yet but the sticky seems to say they fit with no modifications.
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Car: 1985 Z28
Engine: 305 LG4
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
This is the one I got:
https://www.griffinradiator.com/load...key_id=6-70311
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Axle/Gears: 3.08
Doh! I already ordered the OSC 951 at Rock Auto for $105.
