Electric cooling fan motor replacement
Old Dec 29, 2025 | 05:18 PM
Svduke13's Avatar
Car: 1984 Trans Am, WS6
Engine: 5.0 HO l69
Transmission: 5 speed
I’ve got a 1984 TA with L69 HO 5.0 and manual transmission. The stock fan, which is a single electric fan, was very loud when it turns on so I bought a stock replacement motor, ADO-15-8498. The problem is a little lip on the drive plate on the new one that isn’t on the original motor which prevents the fan from seating so o can’t get the fastener on. I can’t find anything different than what I bought. Any ideas? I was hoping to just swap the motor and not have to deal with retrofitting an aftermarket fan etc.
top pic is the original, second is the new one
Old Dec 29, 2025 | 05:21 PM
Svduke13's Avatar
Engine: 5.0 HO l69
Re: Electric cooling fan motor replacement
Also the directions seem to contemplate a thin drive plate option but can’t find it referenced anywhere or where to purchase.
Old Dec 29, 2025 | 07:14 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Swap the flanges.
Old Dec 29, 2025 | 07:29 PM
Svduke13's Avatar
Engine: 5.0 HO l69
I thought the same thing but any idea how I would be able to remove it? It seem like it was pressed on.
Old Dec 30, 2025 | 02:20 AM
matt6simmo's Avatar
Car: 88 Trans Am
Engine: 305 TBI
I actually just swapped my fan motor from the one on rockauto's website a few months ago. That little washer thing came off and the original fan fit right on with no problem.
Old Dec 30, 2025 | 07:30 AM
Svduke13's Avatar
Engine: 5.0 HO l69
Thanks - which one on rock auto did you go with?
Old Dec 30, 2025 | 12:20 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
The delco motors al lseem to have that.. it fits the dual fan blades perfect.
As I recal lif you got the delco unit you needed to also get a new fan / blade..im not sure if that is stil lan option.
but most other aftermarket motors dont have that / have a separate removeable piece
Old Dec 30, 2025 | 08:50 PM
Engine: LT1, L400
Un press it. Use a puller. Easy button.
Old Dec 31, 2025 | 03:07 AM
matt6simmo's Avatar
Car: 88 Trans Am
Engine: 305 TBI
I can't find the order information but I think it was either the VDO or the Four Seasons.
Old Jan 5, 2026 | 05:47 PM
Svduke13's Avatar
Engine: 5.0 HO l69
Hey all just wanted to close the loop. Went with the Continental pm517 fan motor from rockauto and fits perfect. That washer is removable. Thanks!
GASPEDDLER
Feb 20, 2024 04:37 PM
cmk-2
Jun 7, 2022 08:52 PM
Ultraman
Mar 10, 2019 11:26 PM
8t2 z-chev
Mar 28, 2015 01:33 PM
PJ POLING
Jan 20, 2006 10:08 PM
