injector pulse widths decrease at higher rpms?
Old Oct 13, 2002 | 01:36 AM
breathment's Avatar
why do the injector pulse widths get shorter the higher rpms u go? is it because they have less time to fire because the engine is rotating quicker? wouldn't this cause u to have less fuel when u actualy need more fuel?
Old Oct 13, 2002 | 10:46 AM
funstick's Avatar
have you looked to see if the decimal point is moving. what kind of scanning software are you using ?
Old Oct 13, 2002 | 01:33 PM
breathment's Avatar
http://www.fbody.com/members/david88...tool/Book1.htm
here is the data i have gotten from the scan tool. its pretty crappy as it only records for like 3 seconds or so.. but it gets the job done
Old Oct 13, 2002 | 08:00 PM
funstick's Avatar
i dunno maybe the scan tolls istn working correctly. ?? but injector pulsewidth will fall off as the fuel demands of the engien fall of. typically the engine will begin to run out of air at HIGHRPM so you will need less fuel.
Old Oct 15, 2002 | 04:06 AM
89firechicken's Avatar
i thought the motor would get more air at a high rpm due to the fact it's sucking more in and your going faster.
Old Oct 16, 2002 | 12:51 PM
funstick's Avatar
after the engine reachs peak TQ it will typically flow less air. go read some dyno sheets with cfm consumption charts youll see the trend.
Old Oct 16, 2002 | 04:21 PM
breathment's Avatar
the MAF still showed an increase in airflow as the pulse width was decreasing.. look at link above. now the increase in air flow wasn't as great as it was at lower rpms. but it was still increasing..
Old Oct 17, 2002 | 07:13 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Keep in mind that your fuel pressure goes up as the throttle is opened, so it is possible, although mine doesn't.
Old Oct 18, 2002 | 08:49 PM
Andy Bush's Avatar
The pulse width is corrected by the O2 sensor so maybe on low load, you just didn't need the gas to get the revs, and the O2 would go low, so the ECU would cut back on the gas.
On high load, as the engine reaches the peak power it cannot get enough air through the inlet system, the air gets less and less dense as the vacumn starts to increase again, so it cannot handle the same amout of fuel on each stroke. Hence the shorter pulses.
At high revs, the engine produces more power, because it fires more frequently, but after a peak it makes less torque because it cannot get enough air, unless you supercharge, and can burn more fuel at the high revs. That's my guess.
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
someone972
Aug 30, 2015 12:52 AM
86IROC112
Aug 21, 2015 07:20 PM
justin57
Aug 20, 2015 07:05 PM
