Please help, Problems with 950 Commander Install
Old Nov 28, 2003 | 05:35 PM
Ringmaster72's Avatar
Car: 1989 IROC
I have been trying to get this commander 950 installed in My IROC and cannot get it to fire. I am not getting spark. I have changed the entire distributor so I know this is not the problem. I used Holley's wiring harness to install it and also used the holley adapter for the small cap distributor. Is there something I have to hook up specially for the coil to fire? I do not understand why I am getting no spark.
Tim
Old Nov 28, 2003 | 06:31 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
On the engine parameters screen do you have GM HEI checked? 8cyl? Port injection? If not go back & recheck all these with the key in the run position. Make sure it says at the top of the windows header "ECU Data".
Old Nov 28, 2003 | 09:14 PM
614Streets's Avatar
You have ignition power to the coil correct?
Old Nov 28, 2003 | 10:00 PM
Car: 1989 IROC
Thanks Rick, I know they parameters are correct, but I will check to ensure that it says ECU data in the morning.
614Streets, the pink wire on the coil has power when the key is on, What is the white wire for? I am curious as to what these wires run to. I did not know if the old computer somehow fed either the pink or white wires on the coil. Also, sometimes when trying to get spark, I would actually get a spark when i let off the ignition, meaning when I turned it from start to the run position, but I have never gotten any spark when the engine was turning over.
Thaks for the responses
Tim
rocn7roc
Sep 21, 2021 02:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 19, 2015 10:02 PM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
