removing charcol can
Old Jun 10, 2004 | 09:51 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I was wondering about removing the charcol can when I install my dfi this month. I've ripped out my entire tpi harness and I want to know if I should keep the can, get rid of it or what. Emissions is not an issue, but I don't know if you get a lot of gas tank fumes with out it. Thanks
Old Jun 17, 2004 | 10:38 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Just plug the vapor line and you should be fine.
Old Jun 21, 2004 | 08:36 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
if you plug it.. does the tank still vent? I removed mine in my lt1 swap.. wondering if i can remove the line at least to behind the motor.. and if possible block it off.
Old Jun 21, 2004 | 10:57 PM
Our tanks have 4 lines. Fuel feed, Fuel return, Vapor Purge, and the 4th line (atleast on thirdgens) goes to a little valve next to the tank.
I don't know for sure if that is an in valve or an out valve. My guess is that it is in an inlet valve. If it's an inlet valve then when you use fuel it brings in air to replace the space the fuel held.
If you block off the vapor line, it might not breathe right. If it needs to breathe at all. On my jimmy I've just got the line open.
Old Jun 22, 2004 | 08:13 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i beleive that if you plug the vapor line, then you can build pressure in tank, the breather filter should have a check valve, so it only allows air into the tank. same with the vent line, it his a valve (located right by the caninster, that keeps it from sucking air into the tank.
Old Jun 22, 2004 | 04:04 PM
The main valve for the vapor line is in the tank. Its like a pcv valve.
Old Jun 22, 2004 | 04:14 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
i guess by that then, I can plug the line going to the charcol can??
Old Jun 23, 2004 | 01:45 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You really should put a breather in. Normally the excess fuel vapor would be taken up by the can. The pressure relief valve on the tank allows it to build quite a bit of pressure.
Old Jun 23, 2004 | 02:59 PM
Note that if you have to pass emissions, sometimes the vapor from the tank can throw the emissions off.
Old Jun 23, 2004 | 03:00 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The *valve* in the 4th line is a pressure blow off type.
Without the charcoal canister, the tank won't vent.
The ecm expects a slight vac leak when the Charcoal canister is supposed to be on, actually it can account for slightly rich or lean.
If you plug the side going to the engine, you really should have the chip redone to have things done correctly.
One way or another the tank needs a vent, and the vent needs to be able to flow as much air as the engine can use fuel. And it might be more they you'd expect with a healthy engine.
And if your really into *it*, you'll reroute the return line so it doesn't pick up so much heat off the tranny.
Old Jun 23, 2004 | 04:19 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Grumpy's right, you don't want to just block off the lines, the tank will not vent and will build an enormous amount of pressure. I know from first hand experience. I put mine, charcol cannister, back on and ran the line that was originally going to the old carb. and put a small filter on the end of the hose and dropped it down by the power steering box and tied it off neatly. Very few fumes noticable, and the gas tank doesn't do the pressure thing. Vader gave me that idea and it does work.
Old Jun 23, 2004 | 07:29 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
so you hooked up the can, but still vented it to the air through a filter? I would just put it into the TB.. anyway.. I really don't want to put it back on.. I have no emmisions per say to pass. and I have programmed it out of the PCM with tunercat.. just wondering if I can block it.. I'd say the answer is no.. I may cut the line short yet.. or leave it.. I noticed that b4 i took the can off, the tank would build enough pressure that you could hear the pressure relieve when you opened gas cap.. now nothing.. if it won't hurt anything.. i may just leave it be..
Old Jun 25, 2004 | 04:14 PM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Best solution I found was a gas cap off of an early vehicle, such as a 3/4 ton pickup out of the early 70's. My dad happened to have one lying around that worked, so I know they exist. Odd thing though, the chain auto places I searched, listed the same gas cap with EVAP or without, which is not correct. The cap MUST be vented on non-EVAP vehicles, unless there was a breather off of the sender, and say, post-1968 vehicles, I've never heard nor seen a breather tube off of the sender.
Personally, I could never think of a "good" place to run just a vent line (don't like the idea of it underhood, or anywhere near heat) and I didn't like the idea of leaving it "open" so that the tank could theoretically pick up more condensation than necessary.
Now that I think about it, condensation can't be any more of an issue than with the stock setup...you are still taking ambient air, humid or not, and allowing it into the tank. But at least it vents in a "safe" area.
I've heard that this will eat paint eventually, but I'm willing to run that risk compared to the other options.
Old Jun 25, 2004 | 06:58 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
i heard of the cap option.. my beef was that the can takes up space.. more importantly the vapor line runs close to the header.. too close.. wold like to remove line altogether.. perhaps i may investigate putting the can somewhere else.
Old Jun 29, 2004 | 10:02 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
To clarify what I'm looking for. I don't have to worry about emissions but I do worry about saftey. I've ripped out my tpi harness and I'm installing gen 7 with out any of the original emissions crap. I've got an emissions exemption so I don't need it. I think that I would like to keep the can since that seems like the best thing to do. Since I won't have the original computer to send a signal to the valve(?) on the can how do I hook it up? What is that valve(?) do? Thanks.
Old Jul 1, 2004 | 02:33 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
well, a buckshaw way would be to use a relay and a switch, use relay to trigger evap solnoid.. you could even get an electronics shop to gear you up a circuit to trigger the relay say every 5min. they do that with about $5 worth of parts.. and then you wouldn't need a switch..
best of my knowledge is that the computer completes a circuit for the evap can.. probably making a GND.. and that energizes the solinoid to open and allow the engine vacuum to suck the can dry into the intake. then the computer opens the circuit (breaks the gnd) and that closes the solinoid to allow the can to build up fumes again...
Old Jul 5, 2004 | 05:25 PM
I know the 2bbl S10s and thirdgens had a charcoal can ran without a computer. I'll go look at my jimmy and see how it's done. You might consider picking one of those up since it works on its own somehow.
Old Jul 7, 2004 | 02:55 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Remove the Line at the tank...there is a rubber section at the tank.... Put a cheapo imort fuel filter on to vent the tank.... the fumes are Barely noticable UNLESS you stick your nose right next to the filter....
I also tried to PLUG the line and use a vented gas cap BUT that gave me a fuel odor while sitting at stop lights and was also a PITFA to use...
Bottom line is on a TURDGEN ESPECIALLY you need a vent... With the genious design of running the exhaust in the rear right under the gas tank as you drive the fuel heats up and builds Positive pressure....the factory vent is a 1 way valve letting air in preventing a vacuum situation only...Sooo you must have a way to vent the air out....
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
